Hi all! I think i will go down the CDI route. Autronic sm4 with Cdi 500r to be exact. And i was wondering what would be the prettiest way to mount them in a BNR32? i would still like to use the RB26 coil pack cover to have a more stealthy and cleaner look. Is this still possible? I have purchased some LS1 coils which i got cheaply. Is there some way i could mount these (in a cradle etc) and still have it aesthetically pleasing? Where can i get a cradle for the coils? where should the cradle be mounted? is there a way around this? I guess the coil pack cover isnt essential, but id just like to keep it if i can. If anyone has pics of their setups, could you please share them with me?
cheers
chris
https://www.sau.com.au/forums/topic/327084-ignition-coils-for-cdi/
ls1 coils will explode. they have interal igniters.
i have spent ages trying to find a propper "cdi" spec coil for my autronic. i have been using s4 13b 2 post coils. the 1ggze 2 post ones are good to, aswell as gto tt cols.
i dont like the idea of running 2 coils in parallel for waste spark. each coil will be getting halve the energy. but it has been made to work well with the factory 26 coils.
for cdi you want the lowest inductance coil you can find. higher inductance makes good spark in normal transistor ignition, but for cdi they take to long to saturate. they work but not ideal.
motobike coils are the gun thing but ive yet to test any.
in your case id just use the factory coils wired in parallel.
having said all that, i can get a 3" spark from my mazda/denso 13b coils. but they are really big.
Mercury marine coils are the go for a CDI system (the same coil used on a 2.5 2 stroke mercury outboard). Have used them on another car that i have built with good success. These are the coils recomended by MoTec for their CDI8 ignition system. Will have to enquire about costing for you. I will be able to make a nice neat mount for you in keeping with the quality of the rest of the build. But if anyone has picks of their mouning set up would still be interesting to see how other people would approach it.
The ls2/yukon coils would have been a better choice. Check for on google I guess, these are a couple I found.
http://forums.nicoclub.com/another-success...ap-t435099.html
http://forums.nicoclub.com/ls2-truck-coil-swap-t478565.html
http://forums.nicoclub.com/my-ls2-ls7-coil-swap-t353832.html
A few references on how you could set them up. :)
they have inbuilt ignitors and will go pop/bang with CDI.
Yeah no sh$%, that was in reference to his ls1 coils and how he could mount them. He pbly could have just used the ls2/yukon truck coils without going cdi as it's 3 times more powerful according to data all over the net.
Edited by s2d4
the heat treatment's car gtr ran the mercury's with a boot ontop of the plugs and a rod through the hole in the coil's
i paid around $70 each for mine
http://i112.photobucket.com/albums/n179/ma...JUNE022_000.jpg
Edited by Walk510
I use Splitfire with the CBI500R and still had no problem (misfire or start up) with E85 and 2bars of boost.
How much boost are you planning to run mate?
The more you deviate from a stock setup the harder it will be to diagnose problem when it arise.
My Splitfires are 7 years old now, so I need to buy coil packs either way. I'm also going to run vipec xps- cdi unit. If I'm buying coil packs anyway, I might as well get coil packs designed for cdi...
I'm planning to run 25psi and upto 250hp worth of nitrous, so I need a gooood ignition system.
cheers
J.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
