Well lads, I'm formally one of the fold again.
Thanks to our good friend GTR Ken I now have my own GTR sitting happily in the carport:D
Pitty about the bloody weather & these wet roads as I haven't had a chance to have a play yet:(
Look forward to seeing you guys on the street.
Cheers,
Micko.
https://www.sau.com.au/forums/topic/3271-ooh-ahh-gtr/
Originally posted by skyzerr33
i can just see it Micko putting around on the MC day like a granny :lol:
He will to save the tyres for when I have a run in his GTR:)
Ken can you give me some instruction in the art of GTR?
Micko you didn't look THAT nervous.
I've gotta get me one of those GTR's....and some pain killers for the dodgy clutch foot
https://www.sau.com.au/forums/topic/3271-ooh-ahh-gtr/#findComment-57326
What !!, your asking ME. Don't forget I binned one:D
Seriously , you gotta put faith in the ATTESSA and if you have the power slide on in a corner, apply about 1/2 as much lock as you think is necessary and wait for the front torque to come in.Takes a bit of getting used to .
Ken
https://www.sau.com.au/forums/topic/3271-ooh-ahh-gtr/#findComment-57446
Ken
Thanks Ken first corner had a bit too much lock on but figured it must be as you mentioned.
It's an strange feeling sitting there with not as much to do just letting the car do the work.
Rhino
I'm getting addicted to these bloody GTR's
They're an amazing car ....and good fun on a wet road.
The MC day should be great for you and Micko to test the limits safely.
Drive safe everyone I'm off to Phuket for a couple of weeks while the 34 gets a brain transplant courtesy of Dr Lumpy. Can't wait to see how it goes .
https://www.sau.com.au/forums/topic/3271-ooh-ahh-gtr/#findComment-57528
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
