Hey Guys,
sometimes i get a "ticking" sound at idle, if i give the engine a rev it seems to disappear but as soon as it returns to idle it starts ticking again - the car is an R33 GTS25T
is this a sticky lifter or what?
And how do i fix it?
Steve
https://www.sau.com.au/forums/topic/327197-ticking-in-engine-at-idle/
Hey,
I had similar problem, sticky lifter, possible an oil change/engine flush.
I read on here, someone had the same problem, ppl suggest change oil, or it could be the injectors (as they make a noise), just search the site, it should be on here.
Just done an oil change still does it - is lifter noise a problem? can it cause any damage?
i think it may be injectors though as its more a ticking then light tapping
^^ Me three, but mine does it random. Usually when cold and while its coming up to operating temp, once its been up to temp for a while its ok. So must be oil related.
I use Royal Purple, so cant be bad? :blink:
thats like mine,
although i was sure mine was injectors, but not sure if that makes sense if it stops when its warm
Edited by s13-steve
i pretty sure it isnt a problem really - also i thought it could just be the fan
never had any running issues, actually never really had any issues ever with my engine and its done this for as long as i can remember.
i can only hear it when im standing next to the front of my car or have the bonnet up and really listening hard for it.
Yeah nah.
RB25s have hydraulic lifters which can and do wear out. If your lifters are ticking, it means you're more susceptible to valve float at higher revs. From a power output perspective your output will drop slightly due to the decreased valve lift you're receiving.
Injectors don't make the same noise as lifters. And your lifter noise will usually go away with an increase in oil pressure. Rest assured it's not 'fixing itself'.
I would go with injectors on this one.
The ford XR6 Turbo has the same problem from factory and seeing as they based that engine off the skyline they must have thought it was normal :ph34r:
If it really is the injectors then I wouldn't be worrying about it.
get a screwdriver with a long skinny shaft and put the handle to your ear while touching different parts of the engine, its amazing what you can pick up using this method....
exhaust manifold gasket leak is a common one.
Correct! And the oldtimers use a wooden dowel for even better isolation & discrimination of what the noise is and where it's coming from.
More then likely as stated few times,
injectors or lifters. If its freaking you out, get it checked by a reputable mechanic but as far as i know its totally normal. My bosses S5 is crazy loud, hes had it since new, babys it around and its only done 10,000kms. Audi has done all the tests and has forked out for various workshops to check it and put his mind at ease.
Edited by TUFF_350
When its cold isnt that an oil related issue,
just means oil is too thick at start-up, and isnt lubing parts of the valvetrain properly which is why it goes away once warm.., This is why i will get this problem more in winter than in summer,which is why it pays to use a lighter weight oil in winter.
This is what Ive always thought anyway, cause my work ute always ticks more on winter mornings, but goes away after a few minutes..And if i use a !0-40 instead of the usual 20-50 it does it even less..
This injector thing is news to me...but im listening...
Edited by Arthur T3
  • 1 month later...
just noticed it in my r33 series 2 gtst. seems like its coming from the rear (firewall side) of the air intake manifold.
- what is it likely to be, anyone? injectors... right?
Edited by karma_syke
  • 1 month later...
OK guys.. i live in america... seeing as you guys have the r33 in your country im praying on your help!!
I HAVE THIS VERY SAME TICKING NOISE...... happens after the car is warmed up...(rb25 s13) coming from the end of engine/bellhousing area/downpipe.....
It not a multitude of ticks like the injectors..its one steady tick and its not coming from the head..cant hear injectors from insdie the car.. can hear this noise...... WTF?? Theres not many shops around here who know much about these engines... what could it be..? intake/exaust leak? main bearing?.. its a ticking with the revs.. mostly at idle after its warmed up..? shot a vid to see if you guys could point it out.. but the noise is very faint over the engine noise and cant be picked up by the camera...
what was this noise for you guys? It ever get worse or go away!!?
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
