Hey guys,
Just wondering if anyone that has a R34 GT-R has had this happen to them.
i was driving along the other day and out of no where Japanese characters appeared on my MFD. i pushed a few buttons and it wouldn't go away and then a short message in japanese characters came up.
then i turned my car off and tuned it back on, then it just went back to normal.
would anyone know what these messages are trying to tell me?????
thanks,
Veranga
https://www.sau.com.au/forums/topic/327465-r34-gt-r-mdf-jap-writing/
Hey guys,
thanks,
Veranga
That's the whole problem with the world to-day - COMMUNICATION!!! :P
I suppose you were thinking...
"Where's a Japanese literate technician when you need him?"
Tell me about it.
need to have a jap friend handy for these things.
quick question Terry.
what would you have to change for a 80k service in the GTR and when does the timing belt need to be changed???
thanks
thanks
This is from the NISSAN OWNER'S MANUAL for the R34...
And it's in English (from the UK). Re: 80,000km Service.
Legend:- I = Inspect, then replace/correct only if necessary. R = Replace. L = Lubricate
ENGINE AND EMISSION
Engine Oil > R every 5000km or 6 months whichever is first
Engine Oil Filter > R
Drive Belts > I
Engine Anti-freeze (ethylene glycol based) > R
Cooling System > I
Air Cleaner (paper type) > R
Intake & Exhaust Valve Clearance > I if valve noise is evident
Fuel Lines > I
Fuel Filter > R
Spark plugs > I (but should be replaced at 100,000km if platinum)
Heated Oxygen Sensor (ie exhaust gas sensor) > I
EVAP vapour lines > I
Timing Belt > Optional at 80,000km, but to be changed within every 100,000km thereafter
CHASSIS AND BODY
Brake, Clutch fluids (For levels and leaks) > I
Brake fluid if being tracked > R
Brake Booster Vacuum Hoses, Connections & Check Valve > I
Power Steering fluid & lines > I
Brake, Clutch & Exhaust Systems > I
Manual Trans Gear Oil > I
Diff Gear Oil > I
LSD Gear Oil > R
Transfer Fluid > R
Steering gear & Linkages & Axle/Suspension parts, Propeller shaftes & Drive shafts > I
Wheel alignment & Wheel rotation/balancing > I
Brake pads, rotors & other brake components > I
Locks, Hinges & Hood latch > L
Seat Belts, buckles, retractors, anchors & adjuster > I
Foot brake, parking brake & clutch (for free play, stroke & operation) > I
Ventilation Air Filter > R
Supplemental air bag system > I after 10 yrs then every 2 yrs
Some of the above need more attention if using the car for track wk.
Hope this helps :ph34r: And I have to get my 40,000km service done soon; which is the same.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
