Sorry to get off topic, but i need some adivce.
I am able to get a TRUST FMIC and piping straight from japan, at a cheaper price.
It is made for an R32 i have been told
I have an R32 Gts-t, with an R34 turbo running 10 and 13.6 psi, has a 2.5' full exhaust.
What size cooler should i get for best results? 600x300x70?
How much will this improve performance?
Cheers!
meshmesh...for what its worth i have driven a Rb25 with a 2530, PFc, and it had a 600 x 300 x 100 Trust tube & fin cooler, and the thing was still super responsive, it also had a Greddy plenum.
I cant see why this cooler (or similar dimensions) wouldnt be a good upgrade for a GTR with 300rwkws, as for new piping, the HKS/Trust piping kits looks the part, dont know if it really needs to be upgraded, i doubt its worth the money though.
Sorry meshmesh, I though I answered the question, let me be more specific
1. what size cooler?
600 X 300 X 115
2. brand? as each maker claims there name to fame eg: pressure drops, flows etc.
Greddy, tube and fin, they use cast end tanks with nice airlfow shape like the Standard GTR intercooler. Check around, the prices vary a lot, we buy from Nengun.
3. do i need new piping "?lbs pm @ ?litres of pipework"
No, standard GTR pipework is OK for your power target.
Hope that helps
Hi Flaps, a standard R33/R34 GTR intercooler would do the job for you. We see around 20 to 25 rwkw increase from using one on an R32 GTST RB20DET, if you maintain the same boost levels at the turbo ie; about 2 psi more at the plenum.
Hope that helps
Just while we are on GTR coolers, i have noticed that like my Type S cooler, the tubes used in the core are rather thin when compared to most other aftermarket cores i have seen... Hybrid, Plazmaman, Micks Metalcraft etc etc
A lot of ppl seem to ask about pressure drops, flow capability, affect on throttle response, but everyone seems to assume that as 'heat exchangers' they are all equal.
Is it just a case of give or take they are all equal, or is there somthing to Nissan and HKS using the tube thickness they do to ensure maximum heat transfer at a given power.
After all in order for heat exchangers to be effecient they need turbulent flow, not exactly desirable for good flow or low pressure drops...like all things in life its a compromise.
__________________
I don't own or work for a workshop
I don't know everything
__________________
Yeh Right! Between you & warspeed, you guys are too "SMART" for your own booSt's :)
What would this forum be without you guys, thanks heeps. Althought I'm still a little consofused about your formula, in time I'll try to work it out.
  • 1 month later...
Force, I think the Nissan GTR coolers vary slightly depending on which model GTR they came from. Not absolutely certain, but I think R32 cores have one less tube than R33 and R34. Also core thickness changes very slightly (5mm?) as well.
For all practical purposes they are really all the same, if you are thinking of adapting one to another car it does not really matter which one you use.
I am about to take delivery of a '97 R33 GTR which is currently completely stock. I am wanting to do some work to bring horsepower up for weekend track work and have been trying to get as much info regards mods as possible before spending wads of money. Many threads mention going for "as big a FMIC as possible" in the early stages to avoid having to continually upgrade as HP increases. I am unsure at this point, but it would appear from this thread (and please correct me if I am wrong) that the standard R33 GTR intercooler is probably up to the task for most mods.
Hi maccattack,
I'll quote SydneyKid, "Before I can work out whats best I need to know your hp target"
I'm in a similar position at the moment, but as a guide, the SydneyKid flowbenched a stock gtr cooler & they are good for around 300kw at the wheels. Your next bet is the Greedy 600x300x115 using stock piping.
Hey Meshmesh.
Thanks for your comments.
At this point aims are for a staged (ie: bit by bit) increase up to around 300Kw at the wheels. All reading to date seems to imply that cool air equals power, therefore start with the intercooler. In QLD quite often on track temps run high 30 degrees to early 40's, so therefor it is going to be fairly important to keep it as cool as I can. By the sounds of things, the existing cooler isn't bad (in fact quite good), but would chasing 300rwkw (taking into account the ambient temperatures on track) warrant going to a bigger cooler??
Using stock turbos you'll be lucky to get 250-270~@wheels. If you decide on upgrading your turbos "N1, GT2530 etc", then you'll hit 300+
COOL AIR EQUALS POWER... That's interesting, I'm so inclined to go with a Water Injection set up see www.h2oinjection.com (Not the water spray over the intercooler - although this will also help) working something out with skylinegeoff when I get around to it. Even though everything I read seems positive, my tuner is against it full stop. :confused:
I would hazard a guess that if running on days of high temp the a water injection set up should help, the only thing that seems to be standard across the board is avoid running WI before the turbo "as this can damage the blades over time".. still looking into it anyhow.
If turbo upgrades (which no doubt in the future will occur) are required, would the standard GTR intercooler be up to the task based on the resultant heat increases or would I need to increase the intercooler size or increase it's cooling capacity with something like the water injection or intercooler sprayer??
Do not do this, the turbine blades will erode in a suprisingly short amount of time, if not disintegrate.
It would be like running a car with no air filter and pouring in dirt on purpose, straight into the compressor. When a turbine blade is running, it doesnt matter what hits it, dirt or water or whatever, the result would be the same. Not good.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
