I don't think I really need a boost controller? Overkill? I will look into this a little more though in any case. I doubt taking off that little restrictor will make my car boost so much more. If I do blow the turbos... then I will just have to get new ones which don't have ceramic bits! :devil:
i can change the way boost comes on with my avcr. unsure how it works with a say a profec but with the avcr it really makes a difference. comes on much harder than just with say a bleed valve because i can control my boost solenoid.
i'd say every turbo charged car needs some sort of boost controller that is seperate to a wastegate. wether it be a bleed valve or an electronic unit - the restrictor you just pulled out is in essence a "boost controller" =)
taking that restrictor out made you go from what? 0.7bar to 1.0bar boost now???
good place is to mount the boost gauge in the airvent on the RHS of the dash (next to the ignition). it fits gauges perfectly and the gauge will be flush with the dash, thus look like its stock(ish).
and as for the restrictor removel - great move, a good bang for your buck modification! i like the idea also of drilling out the hole to a bigger size to find the perfect boost level that you are after...
good luck with it all,
Warren.
i have recently taken out mine and it dose read just about 1 bar on my gauge. before removing it would top around the 0.5 bar mark a real diffrence , i too got my info from a magazine but i dont recall it saying that mines chip was needed can anyone verify this?
my car has a mines chip and 3.5 inch HKS exhaust.... running 1 bar atm..... i have a R32 vspec... i am sure my turbo's are not ceramic.. can anyone confirm?
If i do have non ceramic.. then it should be cool for me to get rid of my restrictor without having to worry about them blowing.... true?
With more boost, you may need more fuel too... To do that there is a vaccum hose connected toa part of the airflow meter set up, (connects onto a little round thingy) If you take this off and block them both off you trick the car into thinking it needs more fuel all the time instead of just when your driving hard...
Also you can get a diode for your computer to make your car think it is cold all the time, So it idles higher and also provides more fuel... But I don't think you'll need to do anything like that if you have an AVCR
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
