Hi All,
I have been checking the web for a solution to keep a neighbours cat off my V.
I have not caught him in the act so don't know if 1 scare is enough.
I've read that Pepper/Mothballs/Coyote Urine and few other products do the job with mixed results.
Also I have had a look at some of electronic solutions but would rather keep this cheap.
My Car is under a car port and I live in a row of units. Tomorrow I will probably try hanging some moth balls over the hood of the car as thats what the moggie wants to be warm and cozy while leaving mud scratches.
I am not a cat fan !
If anyone has had any experience please share ?
Please don't post if your reply is about shooting or trapping the cat. I just want the cat to stay away from my V !
https://www.sau.com.au/forums/topic/327988-keep-that-my-pussy-off-my-v/
cats hate water, especially cold water, hit the little bast*rd with a hose or bucket full of it when you do catch it, water is a lot more car friendly than napthalene hanging over your bonnet.
He will be there while the bonnet is still carrying heat so it wont be long after you get home
Best idea is to get a cat trap catch the prick and take it to the pound. Else you can get cheap solar powered sensor flood lights. direct it at your bonnet and maybe that would scare it off when it goes off.
Didn't think of that 1 but I'd have to switch it on when I get home otherwise I will blind myself when come into park.
Is there some kinda of spray that is available perhaps in pet store that you can spray to put cats off certain things? If you spray it near the car, that should scare the little rascal away!
I vaguely remember seeing some kinda product like this b4. Not 100% sure though. Perhaps check with a big pet store.
I belive that there is a spray available, just check that it wont harm the duco, as my old man had the same issue with a neighbours cat and i think he used a spray from a pet store.
Also if it is happening during the night and you know who the cat belongs to just inform them of the dusk till dawn ruleing in regards to cats (THEY SHOULD BE LOCKED UP...................................at night)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
