Iam looking for any information on these cars one has become available at a very good price and my girlfriend is looking to buy is there anyway to be able to tell the difference to that of a standard R32 GTR apart from the 17" BBS wheels Brembo brakes and the non finned diff cover and have any been sold in australia recently.
https://www.sau.com.au/forums/topic/32834-r32-gtr-v-spec-ii/
I doubt we're the only three people who have been drooling over that v-spec II.. if your interested in it, and you think you might have the cash, I wouldnt be asking around on forums.. i'd be on the phone to geoff the minute his office opens on wednesday and make sure your first in line.
https://www.sau.com.au/forums/topic/32834-r32-gtr-v-spec-ii/#findComment-658967
Yep already done rang geoff today
https://www.sau.com.au/forums/topic/32834-r32-gtr-v-spec-ii/#findComment-659042
The accident damage is only superficial nothing to bad just a panel which has been replaced, the interior looks in good condition except for the carpet but thats no real drama, the car is totally stock except for what looks like a oil filter relocation kit dont know if it also has an oil cooler looks like a line running to the front bumber so i dont think the engine would of been to stressed or over boosted, most R32 are up around the 120 to 150 k klms now anyway.
Should the chassis code read KBNR32BFS8 AA the 8 denotes that it is a V-spec II is this correct?
https://www.sau.com.au/forums/topic/32834-r32-gtr-v-spec-ii/#findComment-659060
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
