If by internals you mean the interior im pretty sure your dash and seats are good for 800hp however after that they tend to spontaniously combust at random..
And you will also need to change your guages, its a good idea to put them on the bonnet as well
And you will most definately need racing harnesses that dont clash with your flame suit...
Edited by Arthur T3
https://www.sau.com.au/forums/topic/328468-new/#findComment-5340282
i have race seat and harness already and i have AVC-r plus gauges lol 800hp i thought 1000hp hahahaha
https://www.sau.com.au/forums/topic/328468-new/#findComment-5340351
Yeah i thought it would handle 1000 too till myt guages exploded and I burst into flames oneday for no apparent reason,.maybe i had a nawz leak...This is why i stress the use of a quality flame suit... :banana:
If 450 can be acheived safely then its safe to say you could no doubt squeeze 500 out of it..
But like i said before how long do you want it to last..If you got the money just do it...
https://www.sau.com.au/forums/topic/328468-new/#findComment-5340365
With all the supporting mods, a ZOOM feature car made 630rwhp from an internally stock RB25 neo.
But it won't last at all. For reliable power, I'd suggest no more than 450.
It also depends how your engine makes this power (boost, fuel type, headwork/cams etc).
i.e. 20psi from a GT3076 compared to 15psi from a GT3582, obviously 15psi puts less strain on the motor's internals.
https://www.sau.com.au/forums/topic/328468-new/#findComment-5340394
KYP have warned me not to push my engine past 350rwhp if I want it to be reliable. Things are starting to feel the pinch at that stage. You could probably push 400-450, but I would be nervous every time I hit full boost at that power level on standard internals...
https://www.sau.com.au/forums/topic/328468-new/#findComment-5340433
Live life on the edge boys, if your engine aint on the verge of shooting a rod you aint living.
I like this thread.
Right on,
It gunna cost 10-15k just for supporting mods, so if it does blow 2k for another engine is poo change..
turbo 2000+
injectors 1000+
top mount manifold 1500+
cooler 1000+
exhaust 1000+
inlet plenum 1000+
coilpacks 500+
Ecu+ tuning 3000+
Clutch 1000+
other assoretd bits n pieces that you never factor in to your original budget 2000+
Punching a hole through your block and having oil and coolant spew out all over the road in spectacular fashion while showing off in front of your mates....
PRICELESS :banana:
https://www.sau.com.au/forums/topic/328468-new/#findComment-5340655
Guest
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
