Hey,
The brakes started grinding the other day. Took the rears off this afternoon (didn't get to the fronts yet), I'm not expecting perfectly even pad wear but the inner pad on the drivers side was completely worn to the backing whereas the other 3 pads were about 50% or so and still had a fair bit until they would've reached the squeal indicators.
This seems a bit excessive that one pad would wear away completely before the others get to the squeal indicator.
The car is an '03 model coupe 350GT with the brembo calipers. Has anyone else seen pad wear like this?
I'm planning to just clean the sliding pins a bit, put some high temp grease on there and keep an eye on it.
https://www.sau.com.au/forums/topic/328681-brake-pad-wear/
That's pretty unusual, when was the last time you bled your lines? The only thing I can think of is maybe there's some air in one line, which is causing less pressure to the pad. I get marginally more wear on the pads on the left hand side of the car, but that's because the track I usually go to has a number of trail-braked right handers. Even then the wear difference is less than a few mm.
https://www.sau.com.au/forums/topic/328681-brake-pad-wear/#findComment-5343239
sometimes the pistons on the calipers develop rust due to moisture in the brake fluid, if the corrosion is bad it may cause the pistons to seize and wear the pads out faster. get your brakes serviced and make sure the pistons arn't stuck...otherwise you may need new calipers or possibly change the pistons and seals.
https://www.sau.com.au/forums/topic/328681-brake-pad-wear/#findComment-5343456
I had a similar issue with mine, the sliding pins were actually bent, causing the outside pad to never touch. I straightened the pin up in a vice and have had no issues since. It may pay to remove the calliper and check.
Edit: I thought the Brembo's were twin piston in which case one of the pistons is seized.
https://www.sau.com.au/forums/topic/328681-brake-pad-wear/#findComment-5343694
Hmmm, I thought seized piston may have been the case at first, but then I was able to push the pistons back into the caliper (to fit the new pads) using only a screwdriver.
Brake fluid, I haven't changed it yet, bought the car 6 months ago and it doesn't see any track work, but I guess now is a good time to do it. What's the order again? left rear, right rear, left front, right front?
https://www.sau.com.au/forums/topic/328681-brake-pad-wear/#findComment-5343813
if you havent changed brake pads since the car rolled off the ship..then it might just be a dodgy repair shop in japan who replaced pads with used ones...i've seen imports before with different brand brake pads left and right.
just bleed and replace fluids and monitor ur brakes to make sure they arnt sticking....u can usually know if one side wheel is significantly hotter than the other...or gives the distinctive burnt brake pad smell
https://www.sau.com.au/forums/topic/328681-brake-pad-wear/#findComment-5344214
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
