  • Replies 99
Posted Images
Was nice meeting most of you. Sorry got there a bit late (1ish). Some nice rides :bunny:.
So embarrassed i stalled it coming out the car park....sigh.....speaking of which darn that was a stressful car park.
Edited by Blazk
I HATE that carpark. when I shop there, I usually park in the Bunnings carpark and walk around
Thanks to all those that came.
