I've tried searching and couldn't find anything about it. Basically thinking of swapping the NA engine out with a Turboed one but my question is would it make it illegal for a P plater to drive since the car is registered as NA. I've just been curious about this, well technically it would be illegal since it's pretty much turbo and P platers can't drive it but will it bypass that law being the car registered as an NA car. Since that an removing a turbo from a turboed car making it still illegal was just curious and wondering how about if it's vice versa turboing an NA and no car isn't for me, was just thinking of turboing my gf's Supra.
thanks for all the help. please no flaming =[
No it would be completely illegal, first off its a different engine than the one its registered as having which is defectable offense and they will suspend your rego until such time as you either get it engineered or put back in the original engine (also it may void the insurance if you dont tell them as your driving a car with a different engine that wasnt intended for that car). Also if you get pulled over the cops and they pop the bonnet they are going to work it out and then your going to get reamed, 3 points for driving a highpowered vehicle, fine for driving a unroadworthy vehicle and the defect, provided they dont find anything else to pin on you and god knows they will try because they love to ream people who think they can circumvent the law.
I wouldn't call the exemption letter a loop hole...
Given the two people that posted in the vic area about exemptions, saying if they did it again, they wouldn't have bothered.
That pretty much says it all - just get a legal car and drive it until you are off P's
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
