Turbo kit sold, G4 coilovers sold pending payment
Got the footrest from the drivers side footwell?
Pm me a price posted to Adelaide
thanks dude
PM sent
Standard sidemount cooler/ SMIC & piping - $80
will this fit a r33 series 2 gtst if so give me your address and i will come and get it.
sorry mate the SMIC+piping is sold
  • 3 weeks later...
  • Replies 86
Hey i will still take the rb25 clutch master. I will trade my r32 gts cusco fucas for it or i can just straight pay you for it whatever works best for you. I do need it asap so it would need to be shipped express!!!!
yep, still have it here. PM me if you're still keen
coilovers end up selling?
Yep sorry mate G4s are sold
Do you have the antenna? How much posted to NSW 2287
hey mate, it's sold pending payment. i'll let ya know if it falls through
hey do you still have the front lower control arms? what condition are the ball joints in? any up/down movement?
yep still have them. Both in good condition, joints are still firm and no up/down play. PM me if you're keen
cheers
hey mate do u still have the heavy duty clutch? Im keen on buying it let me know asap thanks
Hey mate, sorry it's sold
Hi, do you still have the Drivers side window switch?, will you post it to me here down in tas for $60, let me know, Damo
yup, PM sent
Hey mate...ill take the 5speed box...can u please pm me your number? i got cash waiting..
PM sent
The car didn't come with clear indicators by any chance ?
Sorry mate they sold in like 2 seconds heh
ya mate do you still have the drivers side window motor? would you take $70 bucks and i will pay for the postage of course for delivery to WA with regular express post and also is the window motor still good the last time you used it, i have gone through 3 :yes: thanks
Would you have a front passanger side jesus bar.. (aka the hand u grip on to which is just above your head to the left) i need the handle n the two screw that come with it..
cheers mate...
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
