  • Replies 329
Posted Images
Ill do it then. list updated, DC GTST and Dunc are both in as Chad and Madaz pulled out.
1) DC_GTST
2) Heslo
3) Sam Hawkins
4) Dunc
5) Vu
6) Dohmar
7) Luke - wasntme
8) JMW
9) Foylema
10) Normsta
11) Matt Hawkins
12) Nightcrawler
13) Panzer
14) Bit Sus
15) Brezza
16) Lee
17) Aberax
18) JRM
19) writeoff
20) Skwiz
21) MattyT
22) Volk34
23) Red Back
Hey Damo,
I paid my DD on Monday the 16th August have you received it yet?????It was via Direct Bank Deposit. Dohmar i believe paid before me and he has not been advised of payment either.
Lee
Sory guys, but i gotta pull out of this.
Car will be in the crash repairers over that week, basically up until Skyline Nationals. Might make the trek out there in a passenger seat of some description
My car should be ready Thursday or Friday, so it's gonna be a tight race to get it done.
same here, mines still in the workshop being tuned and suspension upgraded.
i'm hopeful i will have it sometime this week.
PM our treasurer, Ruby. he can sort that out for ya.
Unfortunately, I had trouble accessing SAU for the past many days. Will provide you with an updated list today of who's paid and who hasn't.
:D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
Ă—
Ă—
