So I gather that when you say coilover you are wanting something adjustable because thats supposedly the good stuff right?
just get a decent shock and good spec springs and you have your coilover, if you dont have huge amounts to spend look for decent brands in good secondhand condition, but just keep in mind that just because a mate has 'awesome' adjustable coilovers that are all shiny doesnt mean he will have the right spring spec or have them on the right damper/height settings for the car... most times they dont...
adjustable doesnt always mean good... they may be great for track or racing, but for street with no DIY alignment system and no real suspension setup experience its just not practical... see what what the people in the motorsport section are running and why.
https://www.sau.com.au/forums/topic/328805-your-thoughts/#findComment-5349015
my thoughts:
u dont even need 2 levels of adjustment when they are as shit as most cheap coilovers, there is usually maybe 1 or 2 adjustments with half decent curves, and u have to find them on a shock dyno. people think because they can "feel the difference" when changing the damper adjustments, that they are doing their job. straight up wrong, ur not tuning the performance, ur tuning the ride comfort in most cases.
waste of money, and less performance. thank god for dumb people, otherwise companies would actually have to put more thought into marketing than painting them some pretty colours and putting some knobs on them to play with to sell them.
a lot of damper adjustment is handy when the adjustment is good for teams who have the resources to test and tune properly, but even then it's only handy when the damper adjustment is actually good, basically until you get to around high end koni's level, the damper adjustment is just about useless, even to race engineers let a lone newbies.
it's pure marketing and wank factor.
https://www.sau.com.au/forums/topic/328805-your-thoughts/#findComment-5349054
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
