ok going back awhile ago one my mates had this thing that looked like a gps (stuck on the window of your car and pluged in too your ciga lighter) and it gave you rought 1/4 mile times and 0 - 100 kms and a few other things , they where not 100% but close enough.
my question is WTF is it called i cant think of the name of it and where can you buy them?
thanks
https://www.sau.com.au/forums/topic/328963-1-4-mile-estimator/
if anyone has a Nokia then go onto OVI Store and there is one on there that you can download onto the phone.
It is called RACECHROMO and it was a free download.
it does 1/4 mile, 1000metres, 1 mile, 0-60mph, 0-100kph,0-200kph ( now that would be interesting :blink: )80-120kph plus a few more.
Plus it does laptiming as well.
Cool app.
thanks
they are called a G-TECH.
Called a G-Tech Pro
Found here http://www.gtechpro.com/
thanks
G-Tech Pro SS or RR sounds like it...you can buy them off eBay for a couple hundred these days.
Nothing beats the original, superseded LED G-Tech though...I used to sell them for $100 each. They were very small and surprisingly accurate as long as you kept your end of the bargain when it came to choosing a flat road.
all these things that i have found to be horribly innaccurate. i've mentioned it on here before about the iphone one. i was steering my mates VL, GT35R, nistune, 700cc injectors etc, had the thing flat out for over 20sec before the iphone decided we had completed a 1/4 mile
find a quiet road, measure out 400m, do runs with a stop watch. most people dont realise just how close you can get it yourself, think about it, if you mark two clear lines on the road, you should be able to hit the button to start/stop within a tenth or so of where you should be...
I dunno about the iphone app etc, but many people have tested RSM's and found them to be within a tenth or so of their times on the strip.
Considering it intercepts your computers speed and revs and uses a g sensor to correct, it should be fairly reliable.
exactly. the only ways it will give false readings is from slightly different tyre sizes and if you get wheelspin as it will count that as distance travelled.
It even has a setting the enter your tire sizes to make it accurate again :D And I think the g sensor stops it from counting distance when you are doing xxkm/h but not pulling the g's to match
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
