i installed a gizzmo ms2 eboost the other day and i cant get it off stock boost i did everything the instructions say to do. i know you have to adjust the duty cycle but this isnt doing anything... at 5000 plus rpm it creeps to about ten but thats it . i believe the ms2 uses the same method of boost control as the ms-ibc unit.. if anyone knows why or has a opinion on wat it could be it would be greatly appreciated
https://www.sau.com.au/forums/topic/329064-eboost-trouble/
leet skillz. when you say "ENGINE" where do you mean? do you mean the back of the plenum? the front of the plenum? somewhere else?
have you checked the basics, does the solenoid have power, does it click open/closed when you change boost etc?
does the solenoid only have IN and OUT? some have 3 ports
https://www.sau.com.au/forums/topic/329064-eboost-trouble/#findComment-5348668
the line runing to engine leads to the back of the plenum it has three ports but i am positive its in the right one . how do i check if its working??? by listening to the solenoid while the engines on yes???
https://www.sau.com.au/forums/topic/329064-eboost-trouble/#findComment-5348678
none of the hoses from the solenoid should run to the plenum. the only one that runs from the plenum will go to the guage.
https://www.sau.com.au/forums/topic/329064-eboost-trouble/#findComment-5348689
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
