Im thinking that if the HR3 can record tv and radio it MIGHT record the av inputs aswell. Because I want to be able to have an extra camera inside the car which can record things, just in case my car gets broken into then I will have there pictures. Ha Ha.
careful what you record. you may see things you don't want to.. LOL
  • Replies 76
Posted Images
How good is the tv reception while driving? Is there a hidden aerial in the M35's somewhere? :D
The TV reception is mostly good whilst driving around urban areas. You will get bad spots and you can pick these as all the houses in the area will have large external antenna on the outside of their homes.
The M35 has 4 aerials built into the rear windows, 2 on each side.
Just a quick question why we are on the topic of the aerials.
Is there an adapter that can be used to plug the aerial inputs into the HRII or HRIII or is the only way to splice and dice with the f-connector?
If you had the time, an adapter could be made up if you visit Jaycar, but wont be as neat, and probably lose some signal strength, cutting them into 2 RG59 screw terminals is very efficient and tidy. I wouldnt worry about cutting them, those plugs have absolutely no purpose once the car left japan.
I might talk to Jaycar anyway, there is one up the road and I'm just interested in what solution they could come up with.
Can you tell me what the factory connections are called? i.e. are they a special japanese aerial connection?
Stephen sometimes there is no benefit in reinventing the wheel. Especially when it is going to cost more money.
The current method is very effective and cheap. Something I thought you would appreciate at the moment.
LOL I appreciate it, I just am a big fan of plug & play as apposed to cutting wiring etc. I know, man up! lol
so now i ordered a HR3, what else do i need to install it? these connector things u all talking about... where and how much would be apreciated..
You need a cable from Ducati02 that allows you to run from the hriii (3 rca) to the factory tuner (custom white plug), ducati02 or andy65b will be able to provide more information on that for you.
Hi guys,
If there's have an HR3 left ill grab one. PM me with payment details as I cant PM anyone yet.
And more info on supply of this cable too.
Cheers,
Justin
M35 owners should be aware that the rear window tv antenna wires are ONLY on models that were optioned with factory tv.
if youre considering installing a screen in your non-tv/gps equipped M35, youll need antennas also
same as HR2 but with usb input for playing video and audio files on usb stick. Recommended that M35 owners buy a USB extension cable allowing access to the UBS port, since tuner is usually tucked away out of reach.
Nice :D
Does the TV tuner i ordered come with USB plug in too? It would be killer to be able to play music videos from USB on the screen.
Edited by dimi108
HR3 is TV and USB, HR2 is only TV, both have AV inputs. I have been reassured from Asuka that the USB input will output to NTSC but not the AV input(as was case with HR2), so reverse cameras still need to be NTSC. (for those who did not know, there is a reverse camera switching function)
HR_III_User_Manual_Ver._1.10.pdf
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
