  • Replies 76
Posted Images
If you dont have factory antennas, 2 of these rod style active antennas available for 2x$25 each=$50
good value considering these overpriced ones from HITV http://www.hitv.com.au/products/view.jsp?i...&category=2 retail for around $150 each last time I checked. Ive had them side by side, and look identical to me.
firstly, what car do you have ? pm me your vin # if you want to check for factory TV. depending on model, usually in rear windows, you may have an aftermarket setup for an old analogue tv on front windscreen.
is this available for c34 or just m35? also whats the price difference between hr2 and hr3?
The tuner should work for the C34 also.
The difference is that the HRIII has the additional features.
* Can record digital TV whilst watching another channel.
* Can play MP3&MP4 via USB input.
* Can display photo's.
These are the key differences.
If you are interested in the HRII I have these available in Sydney.
Cheers
Andy
Got my HRIII installed by Andy and Craig.
Stoked with the picture quality. Reception is really good while the car is in motion.
To be honest, TV is a must have.
Haters say that "TV is for wankers", but seriously, it's good shiet. Especially in traffic.
And the women dig it. Keeps them quiet and occupied.
  • 2 months later...
no more left from the 'group buys' and Asuka are unwilling to supply small quantities anymore, so youll prob have to retail shop around, try Chris Rogers @ audio express @ Herston.
ahh that sucks.. i want one too :laugh: ,
herston brisbane?,
could be a goer
Edited by PetroDola
ahh that sucks.. i want one too :D ,
herston brisbane?,
could be a goer
I just bought the last one from Chook a week or so ago. When I found out he had none left I thought I'd ask my "buyer" in China to hunt me down a price on 10-20 of these so I can supply them to forum members at a good price.
Give me a week or two to see if I can get the HR3's in at a good price for you.
That would be great as i pick my m35 up on wednesday. If you get them is there anywhere in brisane / capalaba area that does the install?
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
