hey guys
im going to make this thread a thread about my ride and everything i do to it!
so at 12:43 friday i got a call from my guy.. asking me where i was... at work i replied...
"IVE GOT THE CAR ON MY TRUCK IM TAKING IT TO YOUR HOUSE NOW!"
the next 4 hours were the LONGEST hours ever!... the car landed in melb on tuesday... but its here now!!!
heres what i saw when i FIRST layed eyes on it!!!
came with a "NISMO" booklet? must just be a random book...
Found out what coilovers i have ;):D:D:D:D
Rest of the log book etc...
also found this, a photo of the ppl who previously owned it. im assuming its the dudes wife n kid hehe i reckon they did it on purpose... love thier style
So far the things ive found
Mini di.....AH f**k it...
JUST WATCH THE VIDEO!!!
CLICKITY CLICK CLICK
NEEDS A WASH STILL HAS DIRT IN IT FROM THE BOAT RIDE HERE HAHA
Edited by bLaQ.bOi
my cover is off as it does not fit with the plenum spacer fitted.
I think it is better with the cover off as that plenum gets sooo hot that I figure any extra air you can get to it to keep it cool is good.
Looks nice...
Cheers
Andy
Oh sweet thanks for the info on the optioned parts.
dimi, the wheels are of a v35. i didnt like them at first but they do suit it sooo well for stock looking rims!... i reckon they need to come out about 10-15mm more! and it should sit awesome...
atm the coilovers are set all the way to raised! so ive got about 20mm to drop them. it should sit reallllly good when i drop it, but ill drop it after compliance!
the car sits stupidly low, in terms of everything underneath isnt far from the ground! so i was originally planning on putting 19's on the car but looks like il have to go bigger just to keep the car sitting higher! maybe even 21inch! ( lol id never thought id say i want 21's on my car ever!)
Jetwreck- No i havent, where would the ecu be? im full noob with stageas.
The ECU is located under the dash on the passengers side of the car....just pull the black under-tray off and stick you header under there if you see something that looks like the picture below with the Nismo sticker on it....let me know so I can come and replace it with a standard one for you! :down:
Ready for compliance!!!
its clean finally, although i still havent polished and waxed it!
there ya go dimi :down:
i spent all morning cleaning underneath the car... it almost looks brand new lol. i wish i took photos. maybe when were at compliance if they put it on the hoist. cbfed jacking it up!
cant wait to get it back from compliance and actually drive it! oh and adjust the coilovers to all the way low lol!!!
Jet im going to run outside now and have a look at the computer
OMG OMG OMG OMG
DONT have a nismo ecu :down: hahahah
probably did have one....the owner in Japan more than likely put the standard ECU and sold yours....probably the one I bought of IM recently!
lol......only kidding!
Nice car btw!
Wait till you drive it! It's quicker than a cruiser and quite surprising so the bug will bite. Let me know when you're manufacturing a dump pipe as I would like to buy one.
Looks nice...
Cheers
Andy
My cover is off as well... except mine is off by choice (or lazyness) as the PM35 bonnet is quite a bit higher in the middle than the normal early model bonnet (should've gone with a 35mm runner spacer perhaps? :D).
+1 to the rest (see, I told you - lazy)
Love the remote start/stop btw :D
Edited by iamhe77
rich, i have a bug, but its a v.i.p bug. im going to be turning the car in to as best i can, a very good example of a v.i.p car. i will keep you in the loop about the dump pipes. what size? 2.5? 3?
ill be going a bit of a different way around it than usual. the only bolts that will be on the exhaust will be where it bolts to the turbo...
ill pm you :D
Edited by bLaQ.bOi
Looks super clean!
ill pm you :D
Let me know if you can make me a dump pimp also. I am looking to get my exhaust done. :D
I recon you might change your mind about the bolts once you try to remove the Dump pipe...... LOL
Possibly referring to a V-band clamp arrangement for flange jointing; quick, neat, no leaks, and good for fine tuning fitment of pipework.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
