Steve, i think the reason why some people find the results abit fishy is because there have been a few cars with high hp power readings with no track time or not equivalent times with less then the usual mph. Every one has different views and im just writing what i seem to notice.
ps: jezrrr great results from such little modifications.
  • Replies 56
Cant deacrease scanned image of dyno graph sizue enough to attach.
Its a nice power curve though.
I will get 300RWKW out of these turbos BUt first need bigger injectors (currently running at 90% max) and will be getting stage 1 HKS cams (264 int 264 ext).
May upgrade to GTSS turbos later but want to see what I can get out of the stockers which, in the GTR 34's, are steel wheels and ball bearing.
Jeremy
steve & jezzrrr
you never mentioned what boost you guys ran? I't would be good to see the dyno, & your af ratios also..
ps: steve... so touchy mate :relax: like you say, we here are probably just a bunch of keyboard warriors :D no hard feelings... it makes for a good comparison when we can compare apples with apples....! not dyno queens running 20psi on stock turbos, with af ratio's bordering detonation... that's all..!
Dont mean to interupt your thread but seeing as tho i got a 34 i thought it would be good to compare results.....I got 245kw with 1 bar boost,ganador cat back pipe,japanese "Sift" rewritten ecu...the rest was all standard...i then fitted HKS manifolds,HKS dumps,GT2530's and a trust plenum and at 1.1 bar boost got 298kw.Now fitted HKS cams and gears havent fitted the engine yet so havent dynoed yet....still has the standard front pipe which i will replace after a short dyno run when its running again
Jeremy
Be careful about that assumption though they are ball bearing....
Cheers
Ken
I am running 1.2 bar of boost.
The turbos are safe at that level. "Mr HKS" has acheived some awesome ressults on his R33 GTR. He is getting 421 RWHP with GT SS's @ 1.1 bar of boost !! He has some very nice other mods but is not even running hot cams. He was getting 400 RWHP before moving to the GTSS's so theres some room for improvement.
jeremy
Ken,
ive heard different things about whether theyre steel or not but the consensus is that they are at least from what ive been told
Jeremy
N1's yes , std no.
btw , that came from Mr Jun when I was talking to him about some R34 terbs at Speedworks about 12mths ago
Cheers
Ken
my r34 gtr made 248rwks with mines ecu, pods, exhaust and 1.2bar.
ran 12.8 at 109mph at willowbank with 1.90 60 ft... but didnt really pull that well top end with the mapping in the mines ecu...
so your 278rwks is great , should do a mid 12 if you launch it hard...
since then have gone a little silly fitted hks2530's & hks dumps, 700cc sard, nismo fuel pump and reg.z32afms and super induction kit, power fc....
hope for high 11 or low 12 now even on close to base map in the power fc.
i will be going to the track soon if it stops raining in brisbane everyday....
I will be launching it hard but will have to wait till the HKS twin plate arrives. Those times are pretty decent, what pwoer are you getting now with the 2530's, did you consider the GTSS's ?
Gav Beer from these forums R32 R made 272rwhp on my dyno and ran 12.7, Ask him.
An R33GTS made 306rwhp and ran 12.3. GOTBOOST from this forum ran high 11s in his GTS with 344rwhp on my dyno.PSI2FLY ran 11.5 in a Silvia with 360rwhp.Ian balls SR powered rail ran 8.5 with with 302rwhp, Glen robinsons ford ran 9.1@156mph with 420rwhp in a 1300kg car.Geoff clarks Charger ran 11.4@114mph with 307rwhp,The 1UZ powered Celica from Zoom last year ran 9.1 with 522rwhp as a street car.A XC falcon street car ran 11.18 with 312rwhp,A GTS ran 13.4 last weds with 270rwhp,ND4SPDs Datto 1600 made 440rwhp and ran 11.7@130mph with wild wheelspin and his GTR ran 11.4 with 387rwhp.Simon Nattalotto from this forum ran high 12s with 285rwhp in his GTS, Racetunes Escort ran 13.2 with 170rwhp.Neil rassmussens 2.2 ton 4wd urvan ran 14 with 300rwhp etc etc etc plus we have 20years of outstanding track and rally results so the Dynos very accurate.
steve & jezzrrr
ps: steve... so touchy mate :relax: like you say, we here are probably just a bunch of keyboard warriors :) no hard feelings... it makes for a good comparison when we can compare apples with apples....! not dyno queens running 20psi on stock turbos, with af ratio's bordering detonation... that's all..!
how do you like them apples, :(
(meshmesh not having a go just couldnt resist that one liner)
Hi guys Steve-SST has kindly posted some interesting times and power for Skylines (I have taken the liberty of adding rwkw for the metric minded). If we pick out say 5 Skyline examples and we all put down our own personal experiences, maybe we can shed some light on this……
1. “An R33GTS made 306rwhp (240 rwkw) and ran 12.3.”
2. “GOTBOOST from this forum ran high 11s in his GTS with 344rwhp (260 rwkw) on my dyno”
3. “A GTS ran 13.4 last weds with 270rwhp (205 rwkw)”
4. “GTR ran 11.4 with 387rwhp (290 rwkw)”
5. “Simon Nattalotto from this forum ran high 12s with 285rwhp (215 rwkw) in his GTS”
How does this compare with others’ experiences? No BS please, real timeslip and dyno numbers only.
As an update - Ive just come back from racepace where my car produced 255rwkw @ 15psi boost. We didnt want to increase the boost right now as the car is heading out to Phillip Island next weekend and 15psi is safe for the stock turbo's there.
But there was a power increase of 20rwkw when we upped the boost from 14psi to 15psi so I could see a figure very similar to that produced by jezzrrr @ 1.2bar.
So I got a nice 77rwkw gain by changing over to the power fc, adjusting the cam gears and a slight increase in boost. Very happy with that. And the power delivery is so smooth now. :P
LOL - your car has taken longer than mine. And it was still in bits this morning! My car was meant to be there LAST tuesday but only made it today. So good luck with getting it there on Friday! :P
Dyno took a couple of hours I guess. Didnt pay 100% attention to exactly how long as we were there for ages (I had to run Gerald around to try and find a M7 bolt) plus the cams hadn't been adjusted or the power fc fitted before we got there. And Im not sure as to cost considering I've also had a new clutch, plugs, oil cooler and pads as well as the power fc and cams fitted this last fortnight - and Im not sure of the exact individual breakdown of costs involved. I just know Im broke now.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
