Selling a complete 1jz twin turbs setup. Currently on a MK III Supra.
Open to offers - going the single set-up through ESP.
Any interest?
Yeah I know Supra forums is best but don't have their site addy or the inclination to join that forum ATM.
S!N
https://www.sau.com.au/forums/topic/329965-fs-1jz-twin-turbo-set-up-complete/
What happened to the GTR SiN? Good to see you back here though! I still owe you 2 beers lol :P
Defqon1 THIS YEAR? I'm considering it, was f**king awesome last year (thanks for the tickets lol) but fair expensive.
Sorry about the derailment lol....GOOD LUCK WITH SALE :D
Unfortuantely Transmission died majorly on Staurday night outside the UniPub. Matt has to spend the Turbo upgrade cash on a new strengthend gearbox ($4.5k!!!!!). So keeping the Turbos etc.. till he can resave the cash.
  • 2 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
