  • Replies 43
Oh, and to give a comparison, I could have babied mine around like a grandma, but all of my Kays were driving to and from driving events and at the events. I did 2 track days on one bottom end (Well, actually 3 sessions at half pace each day) and then one texi.
The other one managed to get tuned on the dyno, then make the 3rd session at a track day and everything let go.
Slappers on big turbos do NOT last long...
I've broken 2 now... With a max of 1000KM on them... Pushing 1Bar (14PSi) through TD07S housings, t66 front and a t04r rear wheel.
Nothing below 4000/4500RPM, then everything ramps in over 200/300RPM...
Rev limited at 6600RPM.
On the dyno it made "250RWKW" wheel spinning like a spastic... Using fuel consumption and AFR it would be making around 360RWKW... (69% inj duty on 880cc injectors)
so they were used bottomends not refreshed or anything with twin cam head and big turbo on them?
could i expect anything different considering its got new pistons and bearings?
what exactly let go on them? rods bend or pistons break or the bearings finally had enough or what?
wanna get more than 1000kms out of my rebuilt one hey. if it was a full slapper i wouldnt give a rats. it was meant to be cheap as shit then i decided to go new rings and bearings to refresh it then found i had to bore it out and new pistons. also got the rb25 head full rebuilt so spent extra $750 more than i planned to there. probably just gunna put standard rb25 turbo on it for now but to get some use then il put the big shit on it and wont feel so bad if it lets go.
The bearings will not let go as they are the3 same as the bearings used in aftermarket rods
The rods will not bend until about 600hp or if the tuner detos the engine
the pistons will crack if deto is present but so will forgies they just have a bit more tolerance.
Its all down to your tuner if he is good then your not going to have issues
It comes down to the tune and how you drive it.
My first one let rip with oil surge on a track, mixxed with an over rev when it stepped out in second gear. Well that was the initial thought. Now it appears that the thrust bearings had worn out massively allowing the crank to float and just annhilate everything.
The second motor let rip with what appears to be a cracked oil pump. But this motor spent a shit load of time living life on the hard rev limiter at a motorkhana (Big turbo, very hard to get it to keep the tyres spinning at part throttle without hitting the limiter, if it didn't hit the limiter it bogged and died).
If I drove these motors peacefully, I'm near on 100% sure the second one would still be together today (The first one, probably not... It was a PITA from the get go)
If you can break rods, you're going well. Pistons may let go if it's not tuned properly.
The biggest killer is normally oil control, get a good oil pump on there and doa winged/baffled sump especially if you plan to do ANY form of drivig events (Even if you only do one!!!)
IMO that's the biggest risk with a slapper. My first 30, even though it had forgies, was a slapper crank and rods and the thrust clearance was out.. destroyed an oil pump and almost the block :(
Second pass, I got the crank ground for oversize bearings and it lived a much healthier life (only pulled it apart to upgrade rods and other stuff).
thats it, GOOD tuner
  • 1 month later...
469rwkw on a 3l slapper is the current record in my shop, nothing like a time bomb :/
Slappers FTW if their mates cars who can deal with the consequences if it lets go... a no no for customers :P
Dont just say a figure like that and not give us the details
Sounds awesome I want to know more
std rb30 na bottom end, 26 head and t04z.
about to kill it with a std 1.5jz thats in the shop atm, we matched the output of 469 last thursday... shooting for 500 by the end of the week.
btw both on e85.
looks like i got the only genuine slapper here, 285kw@14psi 6800 rev limit
Rb25 s2 Head Fresh Mill clean slapped on to..
Rb30 s11 Bottom end 70,000kms. Un opened.
ACL 1.3mm Metal Head gasket.
GT35r,
and other stuff but not important here.
not daily driven but 6 dyno tunes, 1 sau dyno day, 2 wakie days, 1 hill climb and 1 motorkhana. love it
i'll let you know how long it lasts...
you have a metal head gasket, not a slapper :down:
i've just got myne running a few backs, still tuning atm but i'm running 23psi from a 1.06 gt3076 through an unopened 150k bottom end, standard nissan gasket etc. will get it on the dyno after tuning to see how much power its making
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
