  • Replies 43
Oh, and to give a comparison, I could have babied mine around like a grandma, but all of my Kays were driving to and from driving events and at the events. I did 2 track days on one bottom end (Well, actually 3 sessions at half pace each day) and then one texi.
The other one managed to get tuned on the dyno, then make the 3rd session at a track day and everything let go.
Slappers on big turbos do NOT last long...
I've broken 2 now... With a max of 1000KM on them... Pushing 1Bar (14PSi) through TD07S housings, t66 front and a t04r rear wheel.
Nothing below 4000/4500RPM, then everything ramps in over 200/300RPM...
Rev limited at 6600RPM.
On the dyno it made "250RWKW" wheel spinning like a spastic... Using fuel consumption and AFR it would be making around 360RWKW... (69% inj duty on 880cc injectors)
so they were used bottomends not refreshed or anything with twin cam head and big turbo on them?
could i expect anything different considering its got new pistons and bearings?
what exactly let go on them? rods bend or pistons break or the bearings finally had enough or what?
wanna get more than 1000kms out of my rebuilt one hey. if it was a full slapper i wouldnt give a rats. it was meant to be cheap as shit then i decided to go new rings and bearings to refresh it then found i had to bore it out and new pistons. also got the rb25 head full rebuilt so spent extra $750 more than i planned to there. probably just gunna put standard rb25 turbo on it for now but to get some use then il put the big shit on it and wont feel so bad if it lets go.
The bearings will not let go as they are the3 same as the bearings used in aftermarket rods
The rods will not bend until about 600hp or if the tuner detos the engine
the pistons will crack if deto is present but so will forgies they just have a bit more tolerance.
Its all down to your tuner if he is good then your not going to have issues
It comes down to the tune and how you drive it.
My first one let rip with oil surge on a track, mixxed with an over rev when it stepped out in second gear. Well that was the initial thought. Now it appears that the thrust bearings had worn out massively allowing the crank to float and just annhilate everything.
The second motor let rip with what appears to be a cracked oil pump. But this motor spent a shit load of time living life on the hard rev limiter at a motorkhana (Big turbo, very hard to get it to keep the tyres spinning at part throttle without hitting the limiter, if it didn't hit the limiter it bogged and died).
If I drove these motors peacefully, I'm near on 100% sure the second one would still be together today (The first one, probably not... It was a PITA from the get go)
If you can break rods, you're going well. Pistons may let go if it's not tuned properly.
The biggest killer is normally oil control, get a good oil pump on there and doa winged/baffled sump especially if you plan to do ANY form of drivig events (Even if you only do one!!!)
IMO that's the biggest risk with a slapper. My first 30, even though it had forgies, was a slapper crank and rods and the thrust clearance was out.. destroyed an oil pump and almost the block :(
Second pass, I got the crank ground for oversize bearings and it lived a much healthier life (only pulled it apart to upgrade rods and other stuff).
thats it, GOOD tuner
  • 1 month later...
469rwkw on a 3l slapper is the current record in my shop, nothing like a time bomb :/
Slappers FTW if their mates cars who can deal with the consequences if it lets go... a no no for customers :P
Dont just say a figure like that and not give us the details
Sounds awesome I want to know more
std rb30 na bottom end, 26 head and t04z.
about to kill it with a std 1.5jz thats in the shop atm, we matched the output of 469 last thursday... shooting for 500 by the end of the week.
btw both on e85.
looks like i got the only genuine slapper here, 285kw@14psi 6800 rev limit
Rb25 s2 Head Fresh Mill clean slapped on to..
Rb30 s11 Bottom end 70,000kms. Un opened.
ACL 1.3mm Metal Head gasket.
GT35r,
and other stuff but not important here.
not daily driven but 6 dyno tunes, 1 sau dyno day, 2 wakie days, 1 hill climb and 1 motorkhana. love it
i'll let you know how long it lasts...
you have a metal head gasket, not a slapper :down:
i've just got myne running a few backs, still tuning atm but i'm running 23psi from a 1.06 gt3076 through an unopened 150k bottom end, standard nissan gasket etc. will get it on the dyno after tuning to see how much power its making
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
