hey guys
i need the following.
i need the gear boot plastic surround and the dash trim part that goes up around the climate control screen.
heater and air con box/fan blower etc.
4 door floor carpet.
b pillar trims
trims for front and rear parts beside the windows and the trims that go between the doors Lower parts only
Door rubbers ( the ones that push on to the Car) not the ones ttached to the door.
Fuse panel cover (in the cabin)
Both Ashtrays and the skyline Factory Cigarette lighter thing.
4 door boot lid
Standard Gear Knob
R32 Power Steering Rack. Hicas or non Hicas
Rear Parcel Shelf 4 door
R32 4 Door Door Trims
Located on Gold Coast Cash Waiting.
Brad 0450 194 170
https://www.sau.com.au/forums/topic/330485-r32-4-door-parts/
hey guys
b pillar trims
4 door boot lid
Standard Gear Knob
Brad 0450 194 170
hey mate i have most of the parts your lokking for apart from carpet parcel shelf boot rack and ashtrays if you still need them pm me
i just purchased some new door seals through von bibra nissan on the goldcoast. there is a 2 month wait tho as they have to be manufactured. part numbers are 76923-01u00 and 76921-01u00 cost me $100 all up if your interested give them a ring on (07) 5556 2966
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
