ok thinking about changing my ecu so ive done some snooping on my rs260 and what i found was that on my ecu theres a garantee plaque on it from mines (number 5063) and also a sticker with the barcode from Hitachi ltd with a nismo sticker below that. Does that meen its a nismo ecu and mines are the tuners.. My camera doesnt like me today so ill get photos up when i can..
Also on another note checked my turbos and they have garrett stamped on the side my question is are the stock turbos garrett or are they after market..
I know they are noob questions but any help would be great...
https://www.sau.com.au/forums/topic/330533-what-ecu/
Get a Power FC, I will slap you if you put anything but that on a 260RS. Haha
I mean don't get me wrong, I have a GReddy EManage Ultimate on my 400hp JZZ20 Soarer, and they are really good. But for an RB26, it will pay to spend a tiny bit of extra coin and get a Power FC tuned for it, PLUS 99%, if not 100% of dyno tuners out there will know exactly how to tune a Power FC on an RB26. You can pick up brand new ones for about $1000 delivered, brand new, from Japan.
Here's the link: Perfect Run Japan - Power FC (Clicky Clicky!)
And this is the part number you will need: 414BN029
As for your Garrett Turbos, yes, they are stock items. Garrett make the turbos for the RB26. GT2530 if I remember correctly. My 1JZ turbos were made by Garrett but they had Toyota CT12A cast onto the compressor housing, but I think the steel label on them said Garrett.
https://www.sau.com.au/forums/topic/330533-what-ecu/#findComment-5369892
I use a PFC in my rb26-powered car, and to be honest, I'm not very impressed. Do yourself a favour and get a Haltech Platinum computer: I'll be switching from PFC to Haltech shortly: much better tune available with the Haltech...
https://www.sau.com.au/forums/topic/330533-what-ecu/#findComment-5369913
Really? Last I checked the tuner has a bigger input than the ECU.
(not knocking Haltech Platinum as they are a great bit of kit)
https://www.sau.com.au/forums/topic/330533-what-ecu/#findComment-5370185
So long as you get a tunable ecu the most important factor is the tuner. Find the best tuner in town and discuss your ecu choice with him (or her) before you buy and install it. The tuner in Sydney whose fame has spread to Auckland is Yavuz at Unigroup Engineering.
Best bang for buck is Nistune but if you want better I would choose the Link (or ViPec). Support and new developments are better for them than for Pfc. The main advantage of the PFC is that there are a lot of tuners around who can use them (how well is another matter!).
https://www.sau.com.au/forums/topic/330533-what-ecu/#findComment-5370276
Really, Micah?
Agreed, the tuner should be the biggest factor in the equation (assuming that the computer suits the car in the first place).
My car is going in to Unigroup next week for a PowerFC retune and clutch change, and Yavuz is an incredibly down-to-earth guy who won't bullsh!t to you about what your car needs. He's got the backing of quite a few people here in Sydney, and justifiably so!
https://www.sau.com.au/forums/topic/330533-what-ecu/#findComment-5370791
yes indeed: I have had the car tuned twice: first by SAS, then by Matt Spry (420AWHP), and I STILL have the annoying "power FC syndrome": the car misses at around 2500-3000rpm when under light to medium throttle... I'm a huge fan of the haltech. That said, I have seen excellent results with the Nistune computer as well.
End of the day, I'll be turfing the PFC: I'll miss the hand controller moulded into the console, but I'm more interested in having a car that runs perfectly (or as near as possible with an aftermarket ecu)...
EDIT: I should probably also mention that I'm leaning towards switching to MAP sensor rather than afm, so the Haltech is ideal...
https://www.sau.com.au/forums/topic/330533-what-ecu/#findComment-5371050
Ahh, the ol' RB26 PFC misfire.
I believe it is an earthing issue but it can be a pain to run down.
The Nistune is the best bet today for a streetable car.
(I had a slight miss on one car around 2500-3000rpm due to the relative difference in the mapped AFR vs closed loop.....the step was too big to provide a smooth transition, leaning out that section of the map ironed it out totally)
https://www.sau.com.au/forums/topic/330533-what-ecu/#findComment-5371511
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
