are you sure you're not thinking of RB25 side feed injectors? this is like all the people who keep saying sard 700s don't fit RB256 fuel rails etc... they do.
I think this is the problem....i believe the the nismo 555cc yellow rb25 is 4 hole and the nismo 555cc pink rb26 is single hole....I have a set here and want to confirm if they indeed nismo... they are rb26 top feed type, Jecs, pink, single hole...hence i asked the question as i "heard" they suppose to be 4 hole
Nismoid...
Does nismo even make a 660cc top feed rb26 injector??? I think it was just 555cc pink and 600cc purple
Any way see if you get those pics
My car ended up making 296kw on 19psi pump fuel.
Then tried for e85 and maxed the injectors and setup at the same power.
I never actually check the nozzle. My bad.
What duty were you seeing with the 600cc @ this power on 98?
Michael im unsure of exact specs of my turbo's or wastegate actuators. I was told by the previous owner he got them off SAU as rebuilt to N1 spec turbo's.
My car loses 1psi by redline But i set my boost controller to have a slight spike
My injectors were at 75% from memory on high boost at 11.6AFR
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
