Decided to strip a complete Rb26 that needs a rebuild. Has low compression on 2-3 cylinders
Was running before removed from car in Japan. I have not seen or heard it running myself. so all parts as is.
Short block c/w crank, rods, pistons, cradle, oil and water pump $575
Sump $175
Head c/w stock cams and valve train $650
Cam covers and front cover, no coil cover $250
Inlet plenum and throttle bodies $450
Injectors and fuel rail $175
CAS $90
Ignitor $90
P/steer pump $80
Alternator $70
Air cond compressor $90
Coils and harness $125
ECU wiring harness $250
ECU stock $110
Knock sensors $75
Engine mounts $50
Oil cooler $70
Turbo's pair $350
Exhaust manifolds $100
Dump pipes $90
Heat shields $90
Turbo inlet piping $125
Twin turbo piping $75
Turbo Oil and Water Lines $140
Clutch fan $50
That covers most parts. Prices neg. Better package prices
If you want the complete package PM your offers
Will ship interstate. Small items thru Aust post. Large items thru www.transdirect.com.au
Pick up post code 4165 Brisbane Queensland. You can get online freight quotes with either service.
https://www.sau.com.au/forums/topic/330900-stripping-a-complete-r32-rb26/
Parts and price update
Short block c/w crank, rods, pistons, cradle, oil and water pump, harmonic balancer. Needs rebuild std bore had water in no2 $575 Now $400
Sump $175 Sold pending payment
Head c/w stock cams and valve train $650 Sold pending payment
Cam covers and front cover, no coil cover $Sold
Inlet plenum and throttle bodies complete No TPS$450 Now $400
CAS $90 Now $70
Ignitor $90 Now $70
P/steer pump $80 Now $50
Alternator $70 Now $50
Air cond compressor $90 now $50
Coils and harness $125 Now $90
ECU wiring harness $250 Now $200
ECU stock $110 Now $100
Knock sensors $75 Now $30
Engine mounts $50 Now $25
Oil cooler $70 Now $50
Turbo's pair $350 Now $250
Exhaust manifolds $100 Now $60
Dump pipes $90 Now $50
Heat shields $90 Now $50
Turbo inlet piping $125 Now $90
Twin turbo piping $75 Now $60
Turbo Oil and Water Lines $140 Sold pending payment
Clutch fan $50 Now $30
Head sold and picked up.
Make me a offer on the complete short block. You might be supprised. Want it gone
Someone must want to rebuild a forged bottom end while keeping there car on the road
Hey Darrin: I'll take the front cam belt cover. Please PM me with contact info. Cheers, Rick.
Sorry sold
This is what is left
Short block c/w crank, rods, pistons, cradle, oil and water pump, harmonic balancer. Needs rebuild std bore had water in no2 $325 pick up only
CAS $60
Ignitor $60
P/steer pump $45
Air cond compressor $50
Coils harness $50
ECU wiring harness $200
ECU stock $100
Knock sensors $20
Engine mounts $25
Oil cooler $50
Turbo's pairNow $250
Exhaust manifolds$60
Dump pipes $50
Heat shields $50
Turbo inlet piping $75
Clutch fan $20
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
