  • Replies 61
Weather is going to be good on sunday, so I'm there.
If not in the skyline, in something else. It's only $85...but just looked at the entry list though.
WTF 58 cars!!!
They better run multiple cars at once.
I'm entered. The sup regs says cars will be released onto the track in intervals of no less than 30seconds. Which basically means no they'll only allow the next car to start when the previous car has just about finished. So guessing maybe 5 to 6 runs at best depending on how many bail after lunch
When CSA were down there last time, the 2nd car was released once the first car had passed the timing mark on the back straight, ran quite well until someone went off the track ...
Sif not being fun in the wet, meant us little tackers (sub 150kw) could easily compete with the big boys (+250kw) :action-smiley-069:
Jump on the Monash/Princess High/Freeway and head east. Moe is ~1.25 hours from the eastern parts of Melbourne
The first exit for Moe has the McDonalds there, easy to see. You do not need to take this exit unless you want some food
You need to take the next exit which is the Newborough/Yallourn North one (it is ~5kms from the first Moe exit above)
Turn left at the stop sign at the top of the exit
You will come to a set of lights, go straight here (if you need fuel, there is a BP on the left before you get to the lights)
Turn right at the next set of lights (which are ~1.5kms from the last set)
Turn left at the roundabout (~400m from the last set of lights)
Turn right into Coach Rd (~400m from the roundabout)
Go up a nice big hill ~1kms and turn right into Bill Schulz Dr
And the hill climb is on the left ~400m
Yeah but you don't want to try and give it as much as I did through corner 3!
Managed a 67.5 which I'm happy with given
never been there before and the issues I'm having with my diff!
Fun track but deadly if your not spot on the whole way around!
I was way off time. I think around 75 and 82seconds. That said I still had fun, and I was happy to not be one of the 3 cars who did get damaged.
Only one looked fairly serious.
And that car that got unlucky and hit by a flying marquee :touch:
Oooo... What cars? Hopefully just WRX's.
i had a great time at HH, first time at the track as a driver, and we were lucky with the weather all day.
i'm not sure about the majority of people, but the minority that i spoke to thought the track was super slippery, the wind was freezing.
it's s tight technical track, that shows weakness in a cars handling very easily.
i found i couldn't attack the straight track as much as i would have liked to as the car was squirming all over the place, and with 0 run off you have to be on the ball 110% of the time.
i managed a 62.something on my last run of the straight track, but would have liked another 1-2 shots at the straight track because i was only just working out which side of the track i should be on at which point, and how hard to push it over the blind crests...
the figure of 8 was a lot more fun for me, i felt the grip levels had improved, and my car preferred the way the track flowed on the figure of 8, better camber through a few of the corners, i think i finished with a 69 something on the figure of 8.
the evo's, sti's and gtr ruled the day though, along with some very quick little mx-5's...
bad luck to the few that had "offs" it really isn't a forgiving place to push it 110% and not pull it off.
russ, casualties were evo x, and a couple of wrx's
for me, a good starting point to build from and i'll definitely be back.
if people spot links to picture galleries on other forums post them up here!
Sorry not all casualties were WRX!
1x EVO 10 LH Front into wall at turn 3.
1x WRX mega smash of LH Front & LH front door at "Oh Sh*t"
1x R32 GTSt LH rear at turn 3 - see below!!!!!!
Here you can see the evidence of the trouble a few of us had at corner 3!
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
