well, went bush bashing with my car the other weekend, and just gravel road and wet stuff everywhere, i did a bit of powersliding and hard accelerating, but got nothing. just dead mind you it goes to 50kg/m that is close to 500nm from memory. thats alot of front tourque. but still, all in all, i got nothing.
hmm, then you should at least take the guages out and check the plug on the rear of the unit.
There is a sticky thread on how to get at the stereo which is pretty much the same thing you need to do.
I must owe you 10c now. Usually these threads have happy endings when they are given some stick in the wet or on gravel.
dammit, lol, i forgot to say ive done that already, all plugs are set etc. i checked them when i replaced my stereo. and at the same time my climate control lights stopped working, so 2 things in my car aint working, climate control lights and my gauge.
anyone know where the sensor is???
or do the r33/4 have the same gauge? my guess it would be for rear tho.
I would change the globes of the climate control. you will probably find that the gauge will start working. I've had it where my rear lights and dash lights were not working. replaced everything but nothing changed. Noticed that one of the globes on my gauge cluster was a little dimmer then the rest. replaced it and tah dah, all came good. very annoying.
oh . dam it o cant remove it . um random . do you know it your car is engaging 4wd ? like fangin it on gravel or get someone to look while you give it a launch . my gauge works everytime i expect it to . about 10% when drivin up a hill and up to 50 doih skids on wet grass. it your car a 1999-2000 series 2 factory manual fr four s or a 260rs ?
none of the others have the gauge and a gtr gauge cluster wont work
does yours have front torque volts and boost from left to right
or something with oil temp init?
I just bought an m35 and mine does seem to be faulty aswell. I works when I punched it up a steep hill in the wet the other night. But unlike other cars I test drove I they would go up a little with some foot planting. Mine just sits on zero all the time..
Is this normal??
I will check the connections and get back to u guys as my boost guage isn't working all the time either..
ok, finally got it working, took the rear out and re-inserted and cleaned out the connectors, now it will jump a little bit on uphills, and it will reach about 20kg-m when i rev at about 4k-rpm and just release the clutch, but it does have a kind of lag effect, i finished accelerating and just let go, the needle still jumps a bit but then slows down. haha. but i guess being a rwd based system with a front added to it, i dont see much transfer going to the front to begin with.
mine is a factory stock standard 2001 rs4 manual, so S or V, i forgot. gauges go from torque- volt- boost.
is facotry boost only 7psi at max???
mine reaches that, but when it gets to it then just cuts out.
i hope your not assuming the factory gauge is in psi ??
7 on that gauge is about 14 psi which is also boost cut level
it is full rear wheel drive untill you break the rears loose . or cornering and shit
Stock RB25DET based cars usually make 125rwkw (+/- 5kw) in stock form at the wheels vs 189kw factory output allowing some loss for age.
Stock RB25DET neo make around 140rwkw with the same things in play.
On a dyno there should be almost no drive to the front wheels with ATESSA unless there is wheelspin so the figures are almost always the same but if you want to allow for some front wheel losses then take away about 10kw.
Using percentage loss can be a slippery slope but is used by some motor engineers, in practice losses are not static but close enough for most of us in streetable cars.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
