I have had 2 KKR turbos fail on me within 1 year. First one failed after 5000-6000km and not hard driving at all....and the 2nd failed after 2000km. No hard driving.
Price sounds right. It's up to you, I have had to rebuild my motor.
The box full of dead ones out the back of otomoto put me off...
900 is laughable when the new price is only 990. Seriously over priced when you see second hand garrett's going for not much more (and sometimes less).
Check out HyperGear's thread:
http://www.skylinesaustralia.com/forums/Hy...ce-t261613.html
if you are looking for a budget. They will be able to put some thing together for that price with lot better result and far better reliability.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
