MODS!!!! sorry guys but i can't edit / report the last thread i made so PLEASE delete that one! it botched up!!! :/
again - sorry for the noobish question but what is a greddy Emanage and what does it do? how does it help or detrement the engine? what does it ACHEIVE
and if i buy one - what MODS do i have to have to WARRANT using one??
or will say - a standard singleturbo 1JZGTE be enough to just "install" one?
i honestly dont know about this sort of thing!!!!
https://www.sau.com.au/forums/topic/331642-greddy-emanage/
they are a piggy back ecu. depending on what version it is determines exactly what and how much you can tune it. the emanage ultimate will allow tuning of both timing and fuel and aren't a bad system to use (rather user friendly with the software setup). they are better than something like a SAFC.
as for what mods will warrant having one, you would see gains on just a stock engine, however i wouldn't bother using one until you were upgrading turbos and/or injectors, etc. and even then it wouldn't be my first choice in ecu's.
https://www.sau.com.au/forums/topic/331642-greddy-emanage/#findComment-5383033
yeah you're right i will
it's just difficult to find "performance" parts for the vvti 1JZ!!!!
i mean i know they're out there... but i don't know what forums to scour... or who makes them or what to buy!
EDIT: i'll fkn NEED moar to combat how effing ricey my soarer is... :ermm:
Edited by Mr Eps
https://www.sau.com.au/forums/topic/331642-greddy-emanage/#findComment-5383449
Rowan - I have an emanage ultimate sitting in my house waiting fo me to stop being a poor ass and buy the harness to suit teh soarer. Had it on the skyline for a while, they are a pretty good thing, not the best for a crazy setup but good for a stockish car.
As the soarer forum guys would say do a BFI and exhaust and you will get 200rwkw and beat every poxxy skyline every built lololololololol :ermm:
https://www.sau.com.au/forums/topic/331642-greddy-emanage/#findComment-5383489
you need a 2JZ.
https://www.sau.com.au/forums/topic/331642-greddy-emanage/#findComment-5383511
Great engine control if you have a good tuner that understands its capabilities. If there is a remap option that would be the best of course.
Pity you aren't in Melbourne, Cihan would be the best option for 1j Emu install around these parts, perhaps you should get in touch with him through the soarer forums.
https://www.sau.com.au/forums/topic/331642-greddy-emanage/#findComment-5383686
i really don't GET what the soarer guys are on about with their BFI fetish...
what does a BFI do that a podfilter won't???
I have nfi lol
my car has it....but un ducted....i think they duct it from the front bar or some shit....not worth the 2hp it might gain lol...just up the boost 1psi and you would gain more lol.
https://www.sau.com.au/forums/topic/331642-greddy-emanage/#findComment-5383814
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
