  • Replies 54
lol. i only weigh 64kg.
so mid to high 200's with the basic mods that i have? i could run 10psi as i have a r32 actuator kicking about but im just worried about the turbo spitting its impellor fins.. and i dont have the cash to upgrade to a hks turbo. i did a boost run this afternoon an it made exactly 7psi on full throttle with standard 25 actuator in 4th gear with no boost controller or stock boost solenoid, just straight boost to the actuator.
Eat less burgers
lol. i only weigh 64kg....
Eat more burgers
Seriously, whip the spare out, any spare tools. Given the weight of the car and the hp your making it wont make much difference. Fibreglass gurads and hood might help a bit.
This thread is halarious.
The only "practical" things to remove to save a bit of weight (however given that your car is stock I don't see the point as you will notice nothing.)
Spare wheel
Factory jack and tools
Factory floormats
Boot lining
Problem is the rear of the car is not the main area that you want a weight saving. The front is where all the weight is on a R33 and what causes it to understeer, thats the hard area to remove weight from.
Honestly one of the best upgrades weight saving wise on a R33 is replacing the factory bonnet with a lighter carbon item. Good weight saving of 10 odd kg (dependent on quality of bonnet) and you are removing weight from the front. Problem is the legality side of things and the quality of the bonnet.
There are heaps of weight saving oppotunities if safety and legality aint a concern, hence for a track car.
Edited by PM-R33
Easy to remove wieght from front :P
When you say Alloytech do you mean the Alloytech V6 found in Holden Commodores?
If so I don't think that counts for the purposes of this thread :blink:
LOL asked how to get the kilos out , this is how just piss off the 25det junker :D
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
