My system is REALLY starting to show it's age. But I've squeezed the most out of it..
Athlon 900
KT-7 Raid board
256 ram
30 gig Seagate 7200rpm drive
Pioneer DVD
Sony Burner
10/100 IBM Ethernet card
32meg Geforce 2 card
SB PCI 128 sound card
External V.90 modem
17 inch digital monitor
It still plays SOF2 multiplayer over the net good, so I might be able to drag out upgrading for a few more months :)
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-56203
Prolly the longest computer i've had, EVER!
Celery 533 @ 800Mhz
abit be6-II (classic overclocking mb!)
384mb ram
32mb GeForce2
SB Live sound card
10/100 network card
scsi card
40GIG hd (2x20)
32x cd-rom
4x dvd drive (plays movies smooth when doing nothing else!)
scsi burner
zip100 drive
cambridge soundworks speakers
19" monitor
will need more room soon for all the dvd ripping i do :)
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-58101
Oldest System:
OS: Windows 2000 Pro
CPU: PIII 800EB
RAM: 512MB PC133 SDRAM
Motherboard: Gigabyte
CDROM: 52x LG, 32x Liteon CD Burner
Sound Card: Soundblaster Live 5.1 Value
HDD: Maxtor 20GB 7200rpm
Monitor: 17" GVC
3D Card: Geforce 2 MX400
Internet Connection: O@H Cable
Newest System:
OS: Windows XP Pro
CPU: P4 2000a Clocked to 2.6ghz
RAM: 512MB DDR33
Motherboard: ASUS P4S-333-C
CDROM: 52x LG, 48x Liteon CD Burner
Sound Card: Game Theatre XP 5.1
HDD: 80GB Seagate Barra 7200rpm
Monitor: 19" Auriga .22dp Flat
3D Card: XFX Geforce 4 Ti4200 clocked to Ti4400 specs
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-58918
Originally posted by inark
Oldest System:
CPU: PIII 800EB
Monitor: 17" GVC
Newest System:
OS: Windows XP Pro
RAM: 512MB DDR33
bitch :shake: :)
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-58925
I just upgraded the other week so i am happy to reply ( other box is only good as a paper weight )
P4 2.6Ghz
533 Front side Bus
Dual Bios
P4 Titan 533 motherboard
SPDIF card
Raid
10/100 Network card
80 gig seagate 7200rpm
64 Geforce 4 mx 440 with DDR ram (SWEEEEEEET)
512 Kingston DDR ram
HP CD-Writer
Sony 52x CD-rom
BLAH BLAH BLAH
Cost me all of $1300 for all that plus keyboard and Optical mouse
eheehehehehehehe ,,, its not what u know, its WHO YOU KNOW!!
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-60187
Where do you lads get your gear from, my puters HELLA old, i ain't even gunna start, but I can't complain I guess.
It's like probably 4 years old, if anyones upgrading and wants to sell their puter then drop me a line or something :D
Too many other things to spend money on then worry about buying a new computer.
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-60230
I've just upgraded from: Dipped Into the Turbo Money :(
Old System:
Asus A7V133 With Raid
Duron 900 (266FSB) @ 1000 @1.75v
SBLive Value (No good with the A7V133 686B South Bridge)
400mb PC133 SDRAM (Generic)
MSI GF2MX400 32Meg
Sold For $250
Fastest Stable Settings:
3DMark 2001SE: 2500
My System Now:
AMD XP1800+ (NEW) $185
EPOX 8K3A DDR333 With Onboard 6.1 Channel Sound (NEW) $185
Corsiar DDR400 XMS 512MB Ram @ DDR333 (NEW) $390
Sparkle GF4 Ti4200 VIVO 128Mb Samsung 4ns Ram (NEW) $350
Std Settings:
3DMark 2001SE: 10,000
I did buy Generic PCB with Samsung TCB3 Chips DDR333 Ram $295) and the 3DMark 2001SE was 7990. :)
In Australia wholesalers must buy 6000+ units of Genuine Samsung PCB & Chip ram which no one has done.
Genuine Samsung PCB & Chip ram is as good as Corsiar, but a little cheaper.
Do not buy Generic PCB with Samsung Chips it is crap.
Corsiar Ram is ready for Overclocking (400FSB) as soon as I get a better Heatsink and PSU Currently got a 250w Aopen and 5v is to low :)
Also spend a little more and get the GF4 Ti Range of Vid cards.
The GF4 MX Vid cards do not support the up and comming games/gfx.
A GF4 Ti4200 Sparkle card overclocked will basically match the performance of the $600-$700 Ti4600.
All up it cost just over $1100 & I'm ready for Unreal Tournament 2003 (30th Sept) and Doom 3 :(
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-61038
i was going to get the Sparkle 129MB card for the same reason... but then i heard about them burning out too fast at those speeds and decided to get the 64MB XFX which has faster RAM and is more stable at 4400 speeds which is good enough.
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-61153
Problem with the 64mb card is that there isn't enough ram for the up and coming games which require 128mb for textures.
i.e Doom 3.
Therefor the game will run slow with a 64mb card as it has to use the memory in the computer.
Slap on a good heat sink with the Sparkle card for the ram chips and you wont have to worry about it burning out.
Where did you hear about this burning out to fast?
I've looked on every forum every review and havn't heard anything but good about the card.
Well apart from the fact that they don't come standard with Heat sinks on the ram.
You Really should have bought a 128mb.
Also please don't listen to what Computer Shop Ppls say.
They simply sell what they make the most on and can get the easiest. Been there done that.
https://www.sau.com.au/forums/topic/3325-home-systems/#findComment-61167
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
