hey....any of u guys goin to the fulllock drift demo thingy tomorrow(sunday)?? Care to meet up somewhere and cruise up there together?? Suggestions of places and time?? i live in S.E burbs so if anyone wants to meet up in the springy/clayton area post it up:):(
UPDATE
**meeting at bunnings carpark opposite sandown raceway at 8:00 leavin at 8:20 sharp and headin down princess hwy to morwell. would be a good idea to fill up first:D:D
PM me for mobile if need be.
https://www.sau.com.au/forums/topic/33250-drift-demo-meet-up/
inark....i thought u got ur spots?? i tried gettin more for my mates but too late too.
for the other guys....its at the Morwell Hillclimb track, 1.5hrs out of melb....limited to 50 people only so if u guys got spots....lets meet at bunnings carpark princess hwy opposite sandown raceway at 8:00...leave at 8:20 sharp and head down princess hwy in the gipsland direction to morwell. heres a link i found with a map.
http://www.vicrally.com.au/event.php?eventID=0057
anyways.....hope to see someone there tomorrow.....pm me for my mobile if need be.
haha...yeah pred....well i had a decent time....got a bit boring seeing the same stuff after a while..so left early. best and consistent drifters of the day were the drivers of the sil-eighty, red 33, red 32 and black 33. they changed drivers heaps in the avo so lost track of who was drivin what:D would have liked to have had a joy ride in one though like those chicks got....grrrrh
Nah, the drivers were mostly the same throughout the day actually.
Due to insurance reasons etc they couldnt really let anyone have a crack at it.
There were maybe a couple of changes at some stages but that would have been all.
Same drivers, just in each others' cars.
There were lots of passenger rides though in the afternoon :)
Sam took me for a spin, gotta love the dorifto!
and why no-one say hello?
I had my blue SAU t-shirt on and everything!!!!
damn!! i was hangin for the passenger ride too!!
didnt see ya there mate. only peeps i noticed was the loud group crackin the funny smartass comments:D:D i was the asian dude with the shaved head and vid cam.
sam didnt look too good in his first couple runs...wasnt sure if he was driftin or trackin it with the lines he was takin....gotta love that 32 though:D it started makin a wierd whirin noise after the first couple runs, sounded like the diff....what was that??
non the less it was a good day. wish we had more like these.
did you see a gook in a green tshirt or a blue rugby jumper? fairly short?
that would have been me ;)
Sam was a bit rusty... but later on in the afternoon, dont worry.
He had it all back again. The first few runs were just getting used to it i think.
the noise was the clutch fan if i remember correctly. On it's way out.
So bit of replacement there :headspin:
Well if you boyz ever wanna do it and fancy a nice long roadtrip up to QLD.. March 21st is the next one. $100, your car and a helmet up here is all you need.. and waltz straight out onto Queensland raceway, and drifto away..
but yeah, it can get a bit repeditive to watch.. i think its one you really have to be out there giving it a crack to get the full thrills :P
  • 1 month later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
