Ok Firstly i appologise if this topic was covered elsewhere, i could not dig up any info.
So i basically got my car together over the past 9months into what is considered registerable state. The last thing required for the engineer and pits is the 5 gas emission test.
Does anyone know any places that do this, given the engineer could not point me in the right direction i thought i would ask on here.
Also given my mild settup (gt35,700cc injectors, microtech and standard cat) what are the chances of passing this. If they are slim what are my options ( in terms of better cat, better tune ect.)
Advice or prior experience would be very much appreciated.
Thanks
D
https://www.sau.com.au/forums/topic/332535-5-gas-emission-testing/
lol dude you need to give us more info than that, I love people that ask questions with gosh darn all background info...
What car? What engine? Is it tuned or not? How much power/boost? How many kms? Healthy motor?
-Standard cat won't do the trick... If I was you I'd get your hands on a euro complaint cat or similar quality (3' high flow cats can still pass emissions - just ask me!) depending on the age of your car (1989 R32 RB20 wont need as tight arse emissions output as say an 2002 R34 RB25 neo...). Make sure the cat is located nice and close to the turbo, less than 2m, so it heats up nice and quick and works best. Put it in the stock position or closer for the best chance of passing. An exhaust shop should have no problem with this, I'd recommend Shawn @ Carline Mufflers Balcatta.
-Get the tuner to tune your microtech for emissions testing, Andrew from Hyperdrive knows such tricks. If it means you have to have two maps tuned, to run one for emissions (i.e. a tight arse map with a slightly lean tune and retarded ignition timing) and one for normal driving (i.e. a more agressive tune). All it should take is 5 mins and a laptop to swap between the two when you get home from the testing.
-Make sure all the factory emissions gear is in place (evap canister etc.) and you have fresh-ish plugs and clean injectors.
At the end of the day it all comes down to the tune and the cat IMO. Everything else helps, but talk to a tuner about your requirements.
As for where the testing is done, ring the DPI and find out, they know all.
Good luck bro!
thanks for your reply
Sorry for the lack of info, it is an RB26, microtech tuned for 18psi, very rich tune judging by my fuel consumption.
Motor has done about 90000km's and is very healthy. Im not looking for a performance cat just one that is very good at reducing emissions. I mean all the makers state they are good but like everything else that may not be the case hence why im looking to find out who has passed this test with similar mods and what cat they were using.
Mild hi-jack here.
Say I buy a car that from factory, came with a turbo, but this was a non turbo model, and then I purchased and installed all the original turbo gear. Would I have to do an emissions test?
Depends what you're talking about. If you mean "turbo gear" as in complete engine, box, breaks, suspension etc... then no, it wont need anything in the way of emissions testing, just an engineer's report for the conversion.
But if you put all the RB25DET gear onto an RB25DE (injectors, manifold, turbo, dump, ECU etc...), then yes, you'll need an engineer's report and an emissions test. This is because regardless of the fact that an RB25DE is almost identical to a DET, you are still modifying the original engine with performance gear, thus altering its emissions.
I see where you're coming from, but the fact is, the stock cat is made for sock power levels, not the ~350kw it's probably making now. And apart from being super restrictive, its possibly almost 20 years old depending on the model of '26 it is, and won't be working anywhere near the way it did when the GTR/stagea came off the showroom floor... Any decent cat from a known brand will do fine so long as its compliant, if it comes marketed as 'euro 3' compliant, then it is, the only thing that differs, is it's flow rate. i.e. Performance cats are still VERY efficient and almost any aftermarket cat is better than the stock piece of shit.
As for other people's experiences, I can't help you here, I have no experience with modified R26s, only my x-trail hahah
I actually thought the same about the cat given it's age, I was looking at a magnaflow one, but I rang around today a few tuning places including the one I use and they all recomended the stock cat regardless of power. The only concern all had was the ecu which I'm trying to replace. I will go for a test as is and see the outcome I guess.
me and a friend managed to pass a 5 gas but only just, was a forged sr20, stock cams, gt3082 top mount, run of the mill highflow cat, we told tuner to keep in mind we were gonna do an emmission test and he took that into account and we passed first go basically
its not a hard test to pass, they didnt test the car on full boost so it doesnt really matter wat turbo ur running, aslong as ur tune is decent and ur cat is working you will be ok
all tests were done in nuetral on idle and also with revs raised for quite some time ( quite a dumb test but works for me :D;) )
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
