White series 3 r31 skyline stolen at some stage during the night last night. Western area (around woodville) Rego no. VBU-982
Stock wheels and everything except exhaust with twin tip.
Any info please contact the police or pm me.
thanks...
Edited by KISIN
https://www.sau.com.au/forums/topic/332642-stolen-r31/
damn another skyline stolen.......i am looking at getting a GPS tracker put in the skyline as well......where did you get yours done lewis and how much was the cost of it all???
Yea same to, i know there's different types of gps, but I know I'm getting real time tracking and I know that another one have like if the car leave an area that you set up it can send or something to your phone.
https://www.sau.com.au/forums/topic/332642-stolen-r31/#findComment-5395124
car found ! had f*ked alternator....dikheads even changed the batery n drove 3 streets away....and dumped it after new batery went flat. Minimal damage luckly... :)
did the police come around and did a fingerprint search?
https://www.sau.com.au/forums/topic/332642-stolen-r31/#findComment-5396546
Are police required to do a fingerprint search if a car has been broken into?
Mate had his car broken into over the weekend - went to the cops and they said "bad luck" and wrote the details down on a piece of paper. They said "we're not going to fingerprint it"
f**king idiots. How else are you meant to catch these faggots? No wonder people take things into their own hands.
https://www.sau.com.au/forums/topic/332642-stolen-r31/#findComment-5396857
no fingerprinting. they were surprised they even found it and it wasnt burnt out. lucky 4 me as there is no insurance on the car !
close call there mate... might wanna get onto that asap :P and get a badass alarm
31s might be getting on but theyre still a rad car
-D
https://www.sau.com.au/forums/topic/332642-stolen-r31/#findComment-5397981
finger printing is over rated
yer when me and steve steal cars we put plastic copies of nightcrawlers fingerprints on a set of latex gloves
its awesome, weve boosted 100 cars and every time andrew gets a body cavity search by the po po
-D
https://www.sau.com.au/forums/topic/332642-stolen-r31/#findComment-5398094
-D
looking at selling/trading it for a 33 shell....need a newer shell to stick an engine in :) so ill just get a clublock for now.
https://www.sau.com.au/forums/topic/332642-stolen-r31/#findComment-5398190
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
