will def put up some pics this weeknd, work stuffs me up cos im usually away during the week and back in sydney for weekends. if anyone needs, i'll be working in the southcoast in Nowra and can pickup from wherever im staying if it makes life any easier.
I'm 10 minutes from Nowra, when are you down here?
  • Replies 57
i should be down there as of tues thru to friday, in the nowra region. is there anything you were after in particular? if we can sort this out then i should be able to bring it down for you :)
sorry Jamo30, too low an offer mate
FMIC kit SOLD
Garage Defend carbon cooling panel SOLD
Whiteline swaybar kit SOLD
Greddy strut brace SOLD
Hicas lock bar SOLD
Bolt on flares SOLD
Rear bar SOLD
Rear Reo SOLD
bootlid SOLD
nissky33- sorry mate my master switch looks bigger than your's posted
Mat34- sure mate ive got a brand new bosch 044, recently used 044, as new walbro 255L intank one as well. take u pick. New 044- $250, used $200, walbro- $120
Update (some might be reposts)
whole bodykit is sold
fmic, swaybars, carbon cooling panel, hicas lock bar SOLD
Top Secret coilovers SOLD
guys make a reasonable offer on remaining items.
PM's sent and replied
Greddy Type S Coilovers SOLD
adjustable suspension arms + Cusco castor rods SOLD
ADDED:
alloy subframe cradle bushes black $100
trim was sold with rolling shell
Box still available
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
