hi all, i was just wondering, is there a standard set of ratios for the 6 speed holinger sequential for the gtr?
what seems to be the commonly chosen ones? 6th being overdrive.
cheers
also, does anyone know what the mainshaft to countershaft distance is on the seq holinger?
ie. the os88 is 88mm....
https://www.sau.com.au/forums/topic/332939-holinger-sequential/
cheers
There are no set ratios, leagh at Hollinger will send you a chart to choose from, Tomei has chisen two different otions.
Imput shaft can be standard 24 spline but most people choose the chevy 26 spline unit as this was a weak point of the original nissan gearbox.
Main shaft to counter shaft distance, call Hollinger.
If you buy one be prepared to put regular gearsets in it, they do wear out and are costly.
  • 9 months later...
pretty sure the GTR hollingers are an HS6 so yeah with the right bellhousing and adapter for the transfer case it should be fine. as long as what you're buying from a V8 is an HS6 too. call hollinger and I'm sure they can tell you. but by the time you buy the right hollinger/RB bellhousing, and the transfer case fitting it might not be worth it. also need to take into account the ratios it comes with might not be suitable.
actually looks like they are not an HS6 after all. and apparently V8SC don't use HS6 now either. it's still possible you could buy one and then buy the bellhousing for the front and the transfer case mount/adapter for the rear but again by the time you do all that just buy the right GTR box?
have a look at the holinger site. it's been updated recently I was told. if you look at the centre of the old GTR boxes (which is the gearbox with the front being just bellhousing and the rear is transfer adapter) it does look a bit like an HS6 but better to check before doing anything.
don't worry I've had that same thought before too.
"hmm, plenty of 6spd sequential hollingers getting around in varous V8SC.... hmmm now how do I put that into my GTR???" lol.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
