Wrecking whole front end of an R32, all components except the long engine for sale, post here with what you're after.
Aftermarket Stuff:
R32:
3 .3 - 3.75" Cat-Back Exhaust: $400
Front Strut Brace: $100
Rear Strut Brace: $100
Carbon Fibre Vented bonnet: $500
Bride Drivers side seat rail (same as most other aftermarket rails): $150
Sparco Drivers side seat rail (same as most other aftermarket rails): $150
Mechanical 1.5 way LSD + housing and half shafts: $950
N1 Headlight (driver's side): $200
Universal (for any car):
2.5" Decat Pipe (S/S): $70
Nismo Gear knob: $50
Short-shifter: $150
Sparco Rev Fixed Back Bucket seat (average condition, has tears etc) $200
R32/R33/A31 Bride Drivers side seat rail (same as most other aftermarket rails): $150
R32/R33/A31 Sparco Drivers side seat rail (same as most other aftermarket rails): $150
3-Point Harness: $50
MOMO "Race" Steering wheel with Nissan Boss kit: $200
GReddy SM Integration Guages + sensors + control unit (water temp, oil temp, oil pressure): $450
3-Layer Copper Radiator: $300
AVS Model 6, 17x9 +36 (pair): $400
Lightweight Jap Wheels (17x8.5 +35): $250
BBS RS 17x9 +20: $1000
Work Meister 18x9/10: $2950
Stock Parts
R32 GTS(t):
Suspension/Steering
2x Front Sway Bar - $50ea
2x Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
2x Front Passenger side Lower Control Arm - $60 -- PICS
2x Front Complete Hub and Brake Assemblys including everything: $280ea
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms - $60ea -- PICS
2x Rear sway bar links w/ Urethane bushes - $15ea -- PICS
2x Rear Hubs - $100ea -- PICS PICS
2x Rear Complete Hub/Brake Assembly's including everything - $170ea
1x Rear Sway Bar - $50ea
1x Rear Subframe - $100
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
2x Rear Toe Rods (hicas) - $50ea
Misc:
2x R32 2dr - Doors - Silver - $300ea
2x R32 Gearbox - $500
2x Indicators: $50ea
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
R32 GTR:
Passenger Side seat with rails: $250
Front Grill: $150
GTR fuel pump
R33:
Standard VLSD with housing and Half shafts: $300
R33 Lower Control Arms - $200pr
S13:
Located in SA near Mitcham, can Post Anywhere
https://www.sau.com.au/forums/topic/333389-the-get-me-back-to-japan-sale/
I'd love to buy 2 of them BBS wheels for skid rims haha
BLASPHEMY
BBS RS's are a cult wheel as well as being wheel pornography, not skidders, clean ur mouth out with soap! :P
Quick Q. Nisskid.
How long are the rear traction arms you have? Two holes in them across the bridge, and are they the same length as the ones that come off the wishbone?
they are standard arms man, stock length. i can get that for u if needed.
I only ask as I was supplied arms from Nisswreck with my cradle, but they have given me arms which I believe from the front of the rear wishbone to the hub.. not the traction arms. Just want to check it all out before I re-attach the rear cradle to the car again.. and if i need to get these said arms you have or not.
Sorry for the confusion, Ive just realised I need Toe arms not traction arms!! They've given me the traction arms!EDIT
Edited by Illest
ahk, atm i only have 1 drivers side rear toe arm
