OK, sorry for the lack of updates, but work got in the way for the past few months, and seeing as it finances the project, I couldn't really say no.
BETTER SAFE THAN SORRY
Having seen a fair number of incidents at the track, and also being a requirement for the race category I plan to enter, I finally bit the bullet and went the full cage. Asking around the racers in WA, one name kept popping up for who does the best rollcages. Brad Stacy. Working for one of the top Race Workshops in WA, and also working from home, I got in touch with Brad, and explained my requirements. Brad was awesome to deal with, and having done dozens of cages before I felt confident leaving my car with him.
The cage took about 2weeks, which wasn't bad considering he was doing it in his spare time. I'm really happy with the end result, and would recommend Brad to anyone thinking of getting a cage done in WA :thumbsup:
http://www.bradstacyfabrication.com.au/
Enjoy the pics
PICTURES
X side bar
Roof X bars
Front view
Rear Cage
Cage Rear Strut
Cage Hoop Top
Cage Hoop Bottom
  • Replies 76
Great work Paul,
Good to see Brad sorted Cage out :thumbsup: .
Whats next dude,
new RB30 :rolleyes:
I'm leaving the engine as is for the time being, makes plenty of power. Likely conversion to E85 fuel though, which should improve response and up the power a bit.
was just wondering about this car just yesturday, how long until it gets back on the track???
Potentially it could go back to the track within about 2weeks, but in order to get everything ready to pass scrutineering it will take alot longer. At least I'm back working on the car again, so progress will be made :thumbsup:
  • 4 weeks later...
just getting my battery nerd on, what are you thinking of using?
you can get pretty powerful motorbike batteries, they already use them in race/drift applications anyway
I'm getting a Braille Battery, only weights 3kg :D
http://www.autocraft.au.com/braille/index.html
bit expensive, but that is pretty light, what one were you looking at? how many cca?
are you looking at the lithium ion technology?
depending on the cca you require i'd say a Deka Powersports ETX18L or ETX30L,
they are a AGM technolgy and should have plenty of power and they could even sit around for 6 months and still start the car.
Give Goodchild Enterprises a call and they should be able to give you a good price on one, even tell them Erik from Bitz sent you
  • 3 weeks later...
stock cams will do 450rwhp wouldnt ever use that much grunt really in a track car, plus you would try to retain vct at any cost possible as it is a very good thing to have while tuning.
very clean car mate did you have a dyno sheet from the engine set up on page 1?
i was also supprised at the weight of the doors as well i have mine off at the moments and there feels like enough metal to make a charade out of them.
how much weight do you think you saved by stripping the wiring harnes out of curiosity?
Edited by kungpow
paul have you disabled the VCT to run the big cams?
looking to do this to mine but cant find out much about it.
Hi Tristan, I've got the biggest VCT cams I could find, Apexi 270degs. I think the VCT is one of the best parts of the RB25s. To be honest you'll struggle to find big VCT cams, so you may be stuck with disabling it.
I do somewhere, I will try and get a copy posted up.
At least 10kgs, I have shopping bags full of it.
  • 4 months later...
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
