Does anyone else in Melb have the 60th Anniversary Edition 32?
I'm in the process of making a very detailed skyline guide including all models, specs, options and special editions.
I've started collecting catalogues...
so far I have
1989 R32 (2 + 4 Door + GTR)
1993 R32 (2 + 4 Door)
R32 VS 1 & 2
R33 S1
R33 S2
R33 GTR
R34 GTt
R34 GTV
R34 GTR
R34 GTR Nur
Nismo R33 GTSt
Any more will be greatly appreciated
  • Replies 59
as for the GTSt RM Spec:
It was a GTS-t Type M which was available for 3 months in a limited sale at Nissan/Prince Saitama in 1993.
It included:
Aluminum bonnet
GT-R type front grill
GT-R type rear spoiler
Red SKYLINE Sticker
R Badge
Full sports bodykit and the gtr bumper as an option
Gold GT badge
Only available in 3 limited colours: black, silver, and white.
Images:
oh yeah, there was also a Type M and a Type J 60th anniversary edition, but I dun have any documentation on em cept for this:
An R32 GTS-t limited vehicle.
It was released as a 60th anniversary vehicle of the Nissan foundation.
Commemorative keys
upgraded interior & trim
fog lamp embedded into bumper
as rear spoiler with high mount brake lamp
GT-R rims on M Spec
i have the key but when my car got here it had the badges removed :D
has the upgraded interior too... well had... until i ripped the drivers seat out and to pieces rofl
hmmmm GTR wheels? how do u know if they are GTR wheels?
probably been taken off mine and replaced with normal GTST rims :D
not that i care anymore seeing as they arent even on the car anymore lol
some enkei 6 spokes... no idea what theyre called... theyre the same as the ones that pushead had on his 33 but not white and 17inch
That white car looks damn similar to my car. I also have the upgrade interior, the high stop light in the spoiler and fog lamps like that. But i have aftermarket wheels, i dont have a special key and my gt badges are either repainted or not the gold ones.
So maybe im not special afterall. :worship:
Do all R32s have a crome grill trim? You know the little bit under the bonnet lip? Or is this special?
Commemorative keys
GT-R rims on M Spec
so basically it was just a slightly factory riced version? :worship:
It included:
Aluminum bonnet
Red SKYLINE Sticker
R Badge
Gold GT badge
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
