Does anyone else in Melb have the 60th Anniversary Edition 32?
I'm in the process of making a very detailed skyline guide including all models, specs, options and special editions.
I've started collecting catalogues...
so far I have
1989 R32 (2 + 4 Door + GTR)
1993 R32 (2 + 4 Door)
R32 VS 1 & 2
R33 S1
R33 S2
R33 GTR
R34 GTt
R34 GTV
R34 GTR
R34 GTR Nur
Nismo R33 GTSt
Any more will be greatly appreciated
  • Replies 59
as for the GTSt RM Spec:
It was a GTS-t Type M which was available for 3 months in a limited sale at Nissan/Prince Saitama in 1993.
It included:
Aluminum bonnet
GT-R type front grill
GT-R type rear spoiler
Red SKYLINE Sticker
R Badge
Full sports bodykit and the gtr bumper as an option
Gold GT badge
Only available in 3 limited colours: black, silver, and white.
Images:
oh yeah, there was also a Type M and a Type J 60th anniversary edition, but I dun have any documentation on em cept for this:
An R32 GTS-t limited vehicle.
It was released as a 60th anniversary vehicle of the Nissan foundation.
Commemorative keys
upgraded interior & trim
fog lamp embedded into bumper
as rear spoiler with high mount brake lamp
GT-R rims on M Spec
i have the key but when my car got here it had the badges removed :D
has the upgraded interior too... well had... until i ripped the drivers seat out and to pieces rofl
hmmmm GTR wheels? how do u know if they are GTR wheels?
probably been taken off mine and replaced with normal GTST rims :D
not that i care anymore seeing as they arent even on the car anymore lol
some enkei 6 spokes... no idea what theyre called... theyre the same as the ones that pushead had on his 33 but not white and 17inch
That white car looks damn similar to my car. I also have the upgrade interior, the high stop light in the spoiler and fog lamps like that. But i have aftermarket wheels, i dont have a special key and my gt badges are either repainted or not the gold ones.
So maybe im not special afterall. :worship:
Do all R32s have a crome grill trim? You know the little bit under the bonnet lip? Or is this special?
Commemorative keys
GT-R rims on M Spec
so basically it was just a slightly factory riced version? :worship:
It included:
Aluminum bonnet
Red SKYLINE Sticker
R Badge
Gold GT badge
