Does anyone else in Melb have the 60th Anniversary Edition 32?
Funky, nice to see your avatar again! Nice research, You can borrow my R33R brochure If you have been a good boy!
Oh and I have had 18 x 8 front and 18 x 9 enkei's rear on my 4 door, looked maaaad!!
  • Replies 59
i've got access to a program that can give you the date of production, batch number, original colour, carpet trim code etc if I gave it a VIN (not the aussie compliance issued one the original Nissan one). If you guys want PM me your number n I'll chuck it in n see what comes up.
yeah I've been on a brochure scanning spree, and working on a joint project with jspec to make it easy to identify your car...
also trying to reverse engineer that software that I mentioned above so I can integrate it into the website.
well its not mine to be givin away (nor do I have it at home) I only have access to it at the J-Spec office :) tryin to figger out a way to make it available to the public tho
That's a mad program that, It even recognises the autech 33 GTR sedan, not to mention you can enter in accident information and it will spit out a list of part numbers required to repair!
Hey inark, you work at crown right? with the schmick GTR?
Me too, i've got the 32 that looks to be NA. I think its one of those limited editions though, its got the gold badges GTR wheel, its got the same key though as other GTS's. I'm not sure if it is or not but a few of those features it has. I changed the engine by the way and the zorst. Shooting for 200rkw soon.
hehe its a GTSt narkeh's got, not a GTR, he just has GTR front fenders...
you've been parkin at crown more often now hey nark, coz I usually park mine a level below yours when I work in the city.
sweet! yeah like shan said its a GTST with the alloy guards and bar not an R... :) yeah urs is a limited edition, not the anniversary edition tho the better one that came with the bonnet and grille and stuff yeah? i used to see it heaps :D
200rw rofl that'll move nicely! :)
shan - yeah park there all the time now... u'll see erics 33 on mez B everyday in the same area to the left of the booth :D
Is the 33 the silver one that parks out the back of the car park all the time. We should make our own little crown skyline club, seeing as there are so many of us! ;)
So yours is a GTSt ay mark, here i was scared to drag you coz of the twins i thought you had under your bonnet, well that changes everything. we should have a few runs along that road after work! :D
Is the 33 the silver one that parks out the back of the car park all the time. We should make our own little crown skyline club, seeing as there are so many of us! :rofl:
So yours is a GTSt ay mark, here i was scared to drag you coz of the twins i thought you had under your bonnet, well that changes everything. we should have a few runs along that road after work!  :rofl:
hehe yeah i always see at least 5 lines there... pusheads is the 33 thats always parked on Mez B near the booth...
no twins... still some nice power tho... ran a 14 flat on stock boost (10psi) heat soaked ;)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
