just wondering, those with an oil cooler....
after running around in your car for whatever period of time, whats the temp of your oil cooler core like?
is it so hot you can't touch it?
is it cool enough to touch for a little bit?
or is it cool?
i had mine installed a while ago, and i dont think its working. its practically cold after a good 15-20 min drive, and on the track i get temps of around 120-130 degrees...as indicated by my factory gauges.
cheers,
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/
It should get quite warm, especially after a "spirited" drive. Even the oil cooler on the mini gets pretty warm after a short drive. Does your oil cooler setup have a thermostat? If it does, maybe that isn't working properly????
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/#findComment-669426
Dunno if the trust kits have a thermostat. HKS kits do, they have an additional return line for when the thermostat is closed.
Pay Anthony a visit, he's got one of each at the moment so you can do a comparison. There's a big difference.
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/#findComment-669558
dudes, isnt 120-130 deg. quite high ???
i got a grex oil cooler and the oil temp sensor is off a sandwich plate where the oil filter is. on my gauge i dont think i have ever scene it above 100 deg, even after givin it a bit. mind u i have never been on the track.
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/#findComment-669697
hahah thanks tony :)
the grex kit consists of an oil filter relocation kit and core.
the core is sitting in the standard kit position and that is just left of middle behind the grill, in between my front mount core and my a/c condensor.
i didnt install it, it was installed by c&v, removed from one car and then straight onto mine. from the block there is a plate replacing the oil filter. two braided lines run to the oil filter relocation kit. from this plate, where the oil filter sits, 2 lines run to the core.
the core is dead cold, the braided lines from the block are warm. i suspect the problem is lying with the plate where the relocation kit sits. but i'll have to check those lines from the block again! :cheers:
in any case, its going to the workshop thursday morning. i just hope its something simple...
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/#findComment-670529
Just thought of something really obvious.
Is the factory sensor reading the oil temp as it is leaving the block, so before it gets pushed through the core.
I only installed an oil temp gauge on the weekend but have noticed that the oil takes a lot longer to heat up than the water. The sensor is reading the temp in the sump which probably has something to do with that, as there is a reasonable amount of oil sitting in there to heat up. Once it is heated up though it stays pretty consistantly around the 90-100 degree mark.
If there is a thermostat in the relocation plate then what you are describing as happening makes sense. Say the thermostat is opening at 100 degrees for example, for every day driving it will almost never direct oil through the core. Then on a track day it's obviously seeing higher temps and going through the core but you are seeing the outgoing temp after it's circulated the block. It's kind of like plumbing a water temp sensor into the top hose of the radiator to see the outgoing water temp from the engine rather than seeing the cooler temp after the radiator.
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/#findComment-671217
Frank: your oil temp is reading awefully high dude...mine reads no higher then 95 degrees during normal drives and goes up to 100 when punting it a bit. I've also set warning 110 degrees. My sensor is also reading straight from the oil cooler and not from the oil lines on the block itself. Also what kind of oil are you using?
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/#findComment-671292
just to clarify guys, my oil temps are perfect for everyday driving and also for a quick squirt. they only reach 130 when im on the track and after i've done 3 hot laps.
BHDave: i am unsure where the factory sensor is, i'll find that out tomorrow :D i had the impression it was sitting on the block where the oil filter plate is...but im really unsure :)
https://www.sau.com.au/forums/topic/33393-oil-cooler-issue/#findComment-671996
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
