Hey people basically im at the stage where im going to stage 2 shall we say in the modification realm. My delemar is im not too clued up on turbo selections for my application, u hear about big turbos chasing big hp but in my case im not after all that. My target is 280 rear wheel hp anything over would be a bonus. Its my daily drive car so i cant go too silly. Basically it dyno's at 213rwhp at the moment which is ok but the additional 70+ hp would be sufficient for me performance wise. I still retain the standard turbo, cooler, computer and injectors. I have a mate who can get me a new front mount which brings me to a question.
For the application im after(280ish rear wheel hp) Is a bar and plate cooler going to be benificial over a tube n fin? Also the standard turbo is blowin abit of oil into the stocko cooler so an upgrade on the turbo side is another question i would like some advice on. Something alittle bigger that offers good throttle response and power when needed. I would like to be running around 14-18 psi MAX as i would like to retain the standard ecu but can make changes if neccessary. Any advice, preferrably positive would be much appreciated, any additional questions or info feel free to ask. Thanx. By the way i have tried search but it doesnt come up with what info im after for my particular application !!
https://www.sau.com.au/forums/topic/33412-stage-2-in-mods-on-rb25det/
MMMMMMMMMMM a search would have gotten you this post of mine from a couple of days ago.....
Hi Steg33, it has been our experience that you can get to 250 rwkw on the standard RB25DET injectors. I'd spend the money on a set of 256/260 Tomei Poncams instead. That will give you a better spread of power than the standard cams.
A ball bearing hi flow of your standard turbo will also get to 250rwkw as well. This saves a lot of hassle and expense with water, oil supply, intercooler and inlet air pipework. All the standard stuff bolts straight back up.
A standard GTR fuel pump would be cheaper than a Bosch and will handle 250 rwkw as well.
I'd save money and buy the Boost Control Kit with the Power FC rather than have a AVCR. They both use the same good quality solenoid, so boost control is equal.
For 250 rwkw you won't need to lower the compression ratio, so a thick head gasket is unnecessary. In fact you don't need to open the motor up at all for 250 rwkw. We don't even think about that until well over 300 rwkw is the target.
and a real search would have found this one from last week...........
this is what we do for 400 bhp with the increases from each part shown in (brackets)...........
* Power FC with Boost Control Kit & Commander (20 rwkw)
* Split dump with mandrel 3.5" exhaust & hi flow cat (25 rwkw)
* GCG ball bearing hi flow RB25 DET turbo (20 rwkw)
* Tomei 256/260 Poncams (15 rwkw)
* Z32 AFM (0 rwkw)
* Pipercross panel filter in the standard airbox (5 rwkw)
* But upgrade the ambient air feed (on a hot day 20 rwkw)
* Standard R33/34 GTR intercooler (20 rwkw)
* 63 mm pipework from the turbo to the intercooler (goes with I/C)
* 75 mm pipework from the intercooler to the throttle body (Goes with I/C)
* OS Giken twin plate clutch (O rwkw)
* Electric fan (remove the standard fan) (4 rwkw)
More importantly, what we don't do...
^ Standard internals are fine
^ Standard compression ratio is fine ie; don't need a head gasket
^ Standard inlet manifold is fine
^ Standard coils are fine
^ Standard exhaust manifold is fine
^ Don't need an adjustable exhaust camshaft pulley, the Tomei Poncams are timed perfectly out of the box
We follow this plan, tune it properly, run 1.3 to 1.4 bar and we get 220 to 240 rwkw (400 bhp) every time, as long as the engine is in good nick to start with of course.
Now if you add all those increases together it ends up more than 220 to 240 rwkw, that's because you don't get the full effect of one without the other (eg; the PFC helps to release the extra rwkw that the turbo produces). And some things, like the Z32 AFM, don't in themselves give any more rwkw, but without it you can't tune the PFC properly. The whole lot is of course useless if it doesn't make it to the wheels, hence the clutch upgrade.
If you want an order, do the exhaust first from the turbo back, the panel filter and then the PFC. It doesn't matter what order you do the rest in. You just have to tune it after each major mod.
There are probably 10 or so more post of mine that would answer all of your questions, let alone other peoples, but I think I have made my point.
Hope it helps
Ok, hiflowing the standard turbo cost roughly how much? I am getting a pwr tube n fin fmic and am probly going to get a forward facing intake plenum aswell. I already have a turbo back exhaust. Its 3 inch with high flow cat and one muffler at the back. I got a k&n pod which was on the car already when i got it and dont have a stock air box to play with. $$$ on those cams?
Where can I get the Tomei Poncams, what sort of price are they going for, and what would you expect a mechanic to charge to fit them?
I asked Nengun mid last year after you personaly recommended me getting them after I queried you in a pm and he said he doesnt sell them.
MRK25T: for tomie cams go to Hi octane racing web site they have a link to the tomie web page and deal them, prices on tomie site are in yen.
Sweetr33: make sure you read the big thread on front facing plenums, theres very good reason to keep the stock one. you cant miss it on a seach ;)
Sweetr33: make sure you read the big thread on front facing plenums, theres very good reason to keep the stock one. you cant miss it on a seach :P
I'm at Tomie's website: http://www.tomei-p.co.jp/_2003web-catalogu.../efr_index.html but I cant see any prices or products. Is it because I dont have a Japanese OS?
Could you quote some prices for the poncams for the rb25det please?
You remove the standard clutch type fan and replace it with something like a Davies Craig fan that is electronic and works only when a soloniod is activated by a certain temp, they are used in all FWD cars and performance cars as it reduces the load on the engine...
They are often also more efficient at cooling thus their use in motorsport...
Also you can get the cams from
www.mercurymotorsport.com.au deliverable to anywhere in oz, and they are on special this month and I am yet to find a cheaper price delivered...
A good condition RB25DET will get close to 208rwkw (280rwhp) using the stock turbo if you offer it the right support such as:
* 3" Turbo Back Exhaust
* K&N Panel Filter
* Power FC+ H/C
* Boost controller (12psi)
* Ex Cam Gear
* Bosch Fuel Pump
* FMIC
Using my limited knowledge I reckon you could get away with all of that for about $5,500 drive away. I believe alot of people upgrade the standard turbo way before what they should (if you have an aftermarket turbo on an RB25DET and your only pushing 200-220rwkw I honestly believe you have wasted your money).
If you really wanted to get a new turbo just get your standard turbo hi-flowed to 450hp for about $2,000
I could only see HKS cams for silvias on special for $750
They were up there last month on special,
Email Trent as ask for a price I am sure he will do very close to the price they were on sale at (unsure of price)...hit him up for free delivery as well... :Bang:
Sweetr33: make sure you read the big thread on front facing plenums, theres very good reason to keep the stock one. you cant miss it on a seach :worship:
As the creator of the big plenum thread, I have to ask what that reason is? I've been running a factory front facing plenum for some time now and have had nothing but positive results.
Something popular in the states is to get the fans off a Ford Tarus from a wrecker. I believe they were sold as Falcons or Fairlanes... FWD family car sold sence ~88 to present... They are really plentyful in wreckers here, and the fans are big and efficent.
Reason: the stock setup can still provide the goods and
a good range of information, why not read it?
a friend of mine has done the conversion and also got good results but their could be a chance it might not so could be a good idea to read the thread and get more info :D
  • 1 month later...
What electric fans do you recommend (got a url?) and approx what are they worth?
Try
http://www.daviescraig.com.au/
You can get them at most autoshops, Repco, SuperCheap, Auto One, AutoBarn, Auto Pro etc.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
