  • Replies 63
I like to cater for the lowest common denominator (sometimes me lol). You can avoid all this if the battery is located in an area that's sealed off from the cabin by a fluid proof bulkhead (firewall).
My RX2 had the battery (big mofo truck battery but that's another story) in one of those cheapo marine boxes in the boot, but the boot was sealed off with an alloy firewall, so all was good (CAMS and DOT legal)
When the car is running, the battery is charging, specially in the first few minutes of operation. It WILL be making an explosive gas. It's highly unlikely that the amount will ever be enough to cause a problem, but you never know.
The other thing to consider is mechanical damage to the battery from things flying around in the boot (or whever it is housed). Normally not a problem, but it can happen. going back to the rally analogy, do you think many people will take the time to carefully stow the spare and tools after changing a flat tyre mid stage?
Edit:
I recall looking over another RX2 rally car a couple of years ago, and he had the fuel tank mounted in the boot, with a "remote" fill point inside the boot (those who've rallied RX2's will know what I mean). The funnel around the fill point (which catches stray fuel and drains it away from the boot or back into the tank) was the typical folded sheet metal arrangement, and the whole thing was sitting directly above the battery.
See where I'm going with this? After many km of vibration, the nice fat insulator above the battery + terminal had worn away to almost nothing by the fuel filler bouncing around above it. This day we were looking at the car, the owner grabbed the funnel and bounced it around slightly and a couple of sparks came off the battery when the funnel touched the battery terminal.
All was fine many years ago when the car was built, but after a while some of the safety gear had worn out, and all of a sudden there was a pretty nasty hazard right there in the back of a rally car. A few cable ties and 100mph tape fixed it, and I'm sure it's still like that today. :P
We all talk about safety and properly engineered cars, but this kind of dodginess does happen, and you'd be a fool to pretend it didn't
As I said before, I like to cater for the lowest common denominator.
Edited by warps
Good consideration for rally people.
Not such an issue for me. If there's any debris flying around to damage my battery I've probably got bigger issues. If it can live in the engine bay without a box, it can live in my boot without one also.
Edited by ActionDan
Yes, but you don't generally carry stuff under the bonnet, whereas the boot is designed for carrying all sorts of things. If you're certain you'll never have any unsecured stuff in the boot, then fair enough. (I know how tempting it can be to throw some tools / spares in the boot when you're transporting to an event, specially when the tow car is already chockers with gear)
I mainly want to know what the best way is for me. I have a fuel system in the boot, just a surge and a pump on the boot floor basically.
Obviously it's seperated from the cabin area by a "flame proof" partition.
My question is, under CAMS, can I mount my battery securely on the other side of the boot, or does it need to be seperate, vapour wise, from the fuel system? ie, In a sealed box venting externally.
I want to avoid having to use a battery box, if only for weight. I'm anal about weight..... why spend an hour finding 300 grams just to add it back with a stupid battery box? :P
Edited by Marlin
I want to avoid having to use a battery box, if only for weight. I'm anal about weight..... why spend an hour finding 300 grams just to add it back with a stupid battery box? :D
I think you can do it that way, but I never feel comfortable having an ignition source so close to a fuel source. That's essentially what the RX2 had, although the battery was in an externally vented marine box so it looked like a more complete installation than having a bare battery sitting in the boot. The scrutes were only ever concerned that the battery was properly clamped down inside the box, rather than how well things were vented.
Besides, with the high quality seals in the RX2, I can guarantee there was enough airflow through the cab / boot to ensure you never had a build up of any gases :)
triangles with sides of 150mm...
My previous log booked IPRA Datto passed pre-race inspection with dry cell battery lying on passenger floor unboxed (bolted down obviously). I can't imagine there would be any problem with having it in the boot with the fuel system.
Edited by hrd-hr30
yeah I've seen many an automobile with a small dry cell securely mounted down in passengers side of cabin (where rear seat passengers feet would be if you had any rear seat passengers or a rear seat)...
  • 8 months later...
Digging up an old thread, wanted to clarify something.
1) As I have my battery and isolator in the same spot do I need both stickers on the car next to each other (plain blue triangle and blue triangle with lightning bolt)?
2) Do I need the lightning bolt sticker if I don't have a remote pull for the isolator? I'm guessing the sticker should go where the pull for the isolator goes, which for me will be right there anyway as I'm going to use the aerial hole.
3) Best place on the rear quarter closest to the battery or on the rear face of the boot lid?
either rear quarter or rear of bootlid is ok. whatever best shows where the battery is. and yes if there's no remote pull for the isolator you don't need to use the lightening bolt yet. as harry said size of those stickers is regulated. they must always be a triangle with 15cm sides.
I wonder marlin if your battery is real. it does have a spelling mistake on it "Coltage"...I guess V and C are next to each other on the keyboard but still surprised that would get through editing of a big company. it may be a copy odyssey?
you can also buy small sealed batteries that have a vent tube built in (they are what you should be buying for a R34 etc). it's easy to fit one of those to an R32 then you just need to drill a hole 8-10mm in the floor, fit a small rubber grommet and then put the vent turbo through that hole. can still box it up too if you like to guard against damage and/or spills and ahve the vent tube pass through the side of the box and then out the floor. they are not particularly expensive either.
OK Cheers for that, I might just go get some cable and hook up that remote pull so it's done then bang some stickers on it.
Love this typo Baron, not hard to see where your heads at :D
Edited by ActionDan
Nice catch on the spelling mistake Baron :)
When I said tell me what you think of the text I was referring to the warning section re explosive gases.
I don't think it's a fraud battery, it's of high quality manufacture and is still going strong, despite being mounted to my diesel high pressure water sprayer and subjected to appalling vibration for weeks at a time while the sprayer and I were out cleaning up after the Queensland floods.
I nicked it out of the 34 before I sold it and it's now mounted in the 32 race car, but I've decided (for now at least) to keep it up the front. By the time a box and all the associated extra cable etc is installed for a boot or cabin mounted battery I think the weight difference will be negligable.
I'm also concerned about voltage drop over longer cable runs..... last thing I need it to not be able to start a stage because the battery won't start it because the cable run is too long and the starter is heat soaked. I've seen it before and it'd be a terrible way to lose an event..... I can find many much better ways to lose :)
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
