Horror stories about what?
Nothing wrong with a 3ltr in a GTR. It's certainly a bit more work involved than say a GTS-T RB26/30 conversion, but i wouldnt go as far as to horror story base it!
Although that said not a lot getting around, I've always wondered how the torque + gearbox would fare over 12-18months with the added torque as GTR's love to strip 3rd as it is without the added oomph.
  • Replies 107
Well given he is a good friend of mine and we were actually discussing it yesterday, I'd be inclinded to believe my version. :)
You aren't the only one, plenty of cars out there are using factory dumps and making 330-380rwkw.
If you are so dead certain the car doesn't have anywhere near the power spend $80 and put it on another dyno and see, would be the first thing i'd do.
(i've gone from racepace to dr.drft, varience of a whopping 10rwkw)
Anyway, proof will be in the pudding - I'll remember this thread for a time when i run a 10 with factory dumps and -5's!
Till then :D
Seems that you talked about it yesterday and he is your friend, l do believe you but that does not mean my car can achieve the same result.
As for putting the car on the dyno. On the weekend there was a dyno day in my local area. l ran my car on the dyno taking into account that the dyno had its correction factor turned on and lets just say the power reading was way off, which confirms from what l am saying that the original dyno figure which as far as l know did not have the shoot out mode turned on is way off the mark but l do not want to get into into a debate how dynos are all different. This is the main reason why l keep ranting on reguarding my setup and the power figure.
Not on purpose either, a friend is organising a drag day in Dec... bit of a bet running as i said i'll run a 10, so did a mate (blown SS commo) :D
Maybe something in the setup has changed, isn't right and so on. Many worms in the can to pull out.
Not saying you aren't right or wrong, I've just never been unsatisfied in any -5 equipped car, they are savage IMO and I've had my own big single @ 370rwkw before in my car :)
Equally fun are GT35 equipped cars which produce very similar numbers etc.
Turbo Dave - His comments are valid and fair, i guess everyone is different mate.
Depends on what you want. Just remember doing it in a GTR is more costly due to sump adaptor and similar things.
It comes down to how much do you want to spend, and how far you want to go.
Rebuilding is not a cheap/easy/fast exercise generally and anyone that's done it can tell you it always costs more than you set out :D
If you don't have at least 10k lying around - i would honestly suggest smaller, better turbos, drive it and be merry for now.
Noely - you wanna come run 10s as well? :D
From what I can gather my current RB26 is a forged engine, so if I can confirm this when the time comes for some -5's it might be a cheap (sorta) upgrade.
Would a Tomei pump and 650cc squirters runs the -5's to the end on the RB26?
If it's as simple as a turbo upgrade and new map sensor I think this will be happening sooner rather than later, 400+ is calling my name??
I believe the Tomei pump will be fine but cant confirm. I would definitely go larger injectors so that you have the option to run E85 at some stage.
Its more about was it built right, in terms of will it hang together @ those power levels, i'd hate to see it not last or something.
I always have that worry i guess with unknown motors :D
But ye, 650/700 & a tomei pump will be fine for -5s on PULP.
You'll need at least 800'c for E85 as you'll be over 400rwkw (provided all things are in order)
Not sure if it's built as yet, has had a tune but we are treating it as a stock motor until proven otherwise.
Running 17psi daily but anymore and the stock airbox struggles up top. I'm going to address this once the -5's come along.
Had an SS a few years back but is was quite dull really. And no matter how much money you spend on getting it going it will always be a "Commodore".
Edited by Turbo Dave
on the topic of stock airbox i think Steve N1 GTR made near 600hp with stock box but really good filter.
when you say struggles what do you mean?
are you sure the stock rubber intake piping isnt sucking in restricting the flow?
take the car to the track and see what 1/4 mile time it does and what trap speed, this will help answer your questions.
or do what i do and drive a slow ass truck all day then go for a drive in the GTR and you will think its crazy fast.
Excellent advise here! Never ride a big bike again and have your memory erased so cant remember what it was like. Cheapest way out of this.
It might have been the older style Turbo's running out of puff at higher revs then. tuner said that when he went for more boost it the boost was getting wavy.
Boost dropped off at 7000 and you could see it fall back on the rollers a bit. as seen here...
Plan to date:
Check engine specs, custom intake, -5's and fuel system to match and life will be good.
I've seen a few vids when GTR's drive past bikes and just gets me wanting, but I still have to be a bit realistic and keep it drivable and not just a top end machine as it will do some interstate drives on occasions.
Had a Heart Failure today when replacing my plugs, No.6 was firm the whole way out and didn't tighten up.
Thought it was going to be an engine out job but found a place in town that Helicoiled it in the car.
That would have been a great excuse for the Missus to accept a rebuild...LOL!!
Locaton slows me down a bit as I don't want to get it rebuilt in my own town.
And I like being married so I tend to tell her the truth.... Most of the time anyway!!
Haven't done comp tests yet might do it next time I do plugs.
What numbers should it read???
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
