Hey guys,
New to this site and proud owner of a 98' R34 25GT =D !!
Ive already left my first post but wants pointers on how all this works?
Also upgrading the hi-fi n wanted to know how to get to ther back speakers..? =S
And im not sure on the manual i downloaded? Who has one they understand!? Just wanna know the specs on my new baby!
Cheers guys!
Speak again..
https://www.sau.com.au/forums/topic/334255-r34-25gt-non-turbo/
lol Sounds almost like you bought a car wihtout knowing what it is. Browse around the forums first and collect data, then specify with questions. Works for me anyways ;)
Ive always wanted a Skyline! Now I have one :D
Was I too look up everything about it prior to purchase?
Used to drive 98' EL XR6 which is sooo easy to do DIY maintenance, upgrades and heaps easire to find little how to's on the net..
I just need a desent car manual for its specs and a few tips from you guys and ill be fine :D
Ive always wanted a Skyline! Now I have one ;)
You'll find plenty of DIYs and maintenance related threads in the 'maintenance' or 'tutorials' section.
I'm running stock rims, because i don't make big power. So no need to overdo.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
