So i just got my first skyline
It has no remote central locking and no alarm system. While i'm at it, i'd like remote start.
I've noticed a huge difference price wise between the main brands (e.g. viper etc) and other no name brands on ebay, but the specs seem to be the same.
Has anyone had any experience in the cheaper alarms? I dont need a state of the art alarm but i dont want to have somthing installed that gives up after a few weeks.
any thoughts?
cheers,
https://www.sau.com.au/forums/topic/334327-which-car-alarm/
Viper #1
also with the amount of threads of cars getting stolen
dont buy a cheapo if you value your car
really? so you are happy with an alarm that only drops the starter?
autowatch for me thanks. drops 3 ckts requires a proper installer to fit the thing and its oz stds - something the viper is not.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5429888
  • 3 weeks later...
all comes down to who installs it, no matter what alarm system it is the install is the main issue because you get lazy installers who dont solder and leave wires exposed so be carefull who you take it to.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5461260
I've also been looking at the ebay ones compared to ones in autobarn. The ebay ones (for $45) have the same specs - sometimes more - than the ones in the stores. Might just buy a cheapo one and see how it performs, not a huge loss if it packs in on me, car is always locked away so can always get a expensive one.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5474784
any thoughts?
cheers,
remote start is highly illegal in Australia (ADR rules suck)and a defect
so is the turbo timer function of some car alarms
and check your insurance, cause some won't cover you unless it is an AUSTRALIAN approved model
some shops won't install ebay crap, and a how about a warranty ?? shop local, buy local for support reasons
don't try to install it yourself
a guide for approved car alarms and other info
http://www.nrma.com.au/documents/brochures/crimesafe-car.pdf
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5481707
Another option is GPS tracking systems, I fit them for www.intellitrac.com.au, basic tracking systems starting from $299 fitted might be an option for use. If you need more info feel free to pm me
Edited by gelousi
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5485055
Hi guys,
I'm the Australian Government and we don't want anyone to have unique or interesting cars, because, you know, only hoons drive nice cars.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5485305
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
